Hobbit Athena Engine Modifications
Hello all.
My case modifications are in progress.
Might need a few tips / tricks if anyone has some thoughts.
I already welded around my base to where I should be comfortable.
I didn't like the jb-weld method for a long term / permanent solution.
Should I be looking to fill behind the flywheel so I can really hog this thing out or is that more trouble than it is worth?
As for getting it back flat its going to take a lot of file strokes and sandpaper work is it not ?
Planning on running a base gasket + spacer + base gasket, felpro karropak.
unmodded Athena stock size
Graham cut hobbit head
70cc head gasket probably modded slightly
'race/stuffed' crank
TJT
CDI ignition with retarding box
Leo Vince pipe
vm18 or vm20 with home-made or mlm intake depending on what I find around for piping.
Thanks.
Re: Hobbit Athena Engine Modifications
Didn't really get a close up.
as far as tips for welding.
bumped to like 50% cleaning action than normal.
I prepped the piece by preheating and brushing.
It sucks to weld because of the contamination and porosity but once you get a good fill base its not half bad. 3/32 I think, green.
Bursts seemed to help. Kind of drop a dot of fill and smooth it out then repeat.
The final product will have some holes though.
Flatten with either a well setup mill or my technique is usually a file with part masking taped over.
You can remove high spots with a dremel, then run the masking tape covered part of the file on the unmodded edge. Keep scraping down at the welded edge with the uncovered file edge until it matches the original. Then a few passes with a fine file across the whole base to clean up. Sharpie the base before this to be sure there's no low spots
That’s a cool technique. May try this when I build a large port Puch kit
Overpriced Parts /
You just figured this out now !
TOTALLY glad I asked!
I always wanted to do an athena kit properly but always wanted it to do myself.
Im going to hit up the store for some files tomorrow, thanks fam.
more pix to follow.
Is that an exclamation or a question roffsroyce
No even I know what I typed. I was way too excited!
Hobbit holder
do you have the alignment dowels in there? doesn't look flush to me but might be optical illusion.
I in fact do have the dowels but thank you for helping me double check.
Found a guy in town with a surface grinder and he said he could probably take this as is and flatten it but yall seem to be able to do this at home so I gotta try it also. Maybe v2 will be done right.
Gonna cut some templates and figure out if I built up enough weld to match the Athena.
What ped/scooter is the Athena originally made for?
It’s made for the Camino, which is a euro hobbit. I’m not sure on any differences in the case, but I know the variator and driven pulley are different. It is possible there are other nuances.
Ana L. of the Aurora Roras /
Spray glue a few different grits of paper on glass or stone. Deck it flat looking for low spots that could leak. 320, 400, 600..
I need to weld more. I cut out an outline of the kit and i need to go further on the deep side of the case. Monday, more progress.
The Cheetachrome Athena case
We're welded up fam.
Left side Dr kit 60mph, right side???? To be continued.
Open up the kit transfers then match to the case, sharpen the transfer stuffers cut a hole in the top of the piston, get a larger mass head shorten and sharpen side skirts. Careful going too deep on the ignition side it gets thin, or add some material to the top. I’d get some alumaweld and melt it in there.
Go ahead’n Hogg it out!
Looks like u have plenty of space now with the extra welding. Cutting a large transfer definitely goes out of the sealing surface. A lot of guys build it up with alumaweld. Easy to apply once u get the hang of it. I piled it up 1/2” thick a couple times. Fuck, now I wanna get some more.
Lay it on a solid flat surface with sandpaper glued or taped down, drag it back and forth to deck it the last little bit.
Want to reply to this thread?
