Morini M1 Tuning
Hey all,
Picked up my first Morini powered moped. 1987 Sebring LTD with 1.9 miles on it. Not a typo.
Before I take the motor apart to change all the seals / gaskets / etc, I'm curious as to what simple - stock looking - mods are most impactful for this motor. Have a lot of experience with A35 / A55 and E50 motors so feel free to be technical.
Moped is bone stock with a 14.12 SHA and the 9mm intake. Found a 14mm intake on Ebay in Italy that I scooped up and am waiting to arrive. While I wait, I'm curious as to what you all can suggest in the way of a carb (bigger SHA? Vm18? Stock for the venturi effect?). I'll eventually end up with the MLM side bleed pipe at some point.
Looking for a "reliable" 40mph. Ped currently does a steady 25mph
Thanks!
Andrew
Re: Morini M1 Tuning
Mikey Antonakakis /
Get a kit on there, and a little bit stiffer clutch springs. Not crazy high stall, just a little more than stock. With a pipe and decent carb, you'll be closer to 45-50mph with good acceleration. It doesn't end up being a very high strung motor (especially if you don't go with a high RPM pipe), so shouldn't have any reliability issues, at least none that you wouldn't have had regardless.
No point going any bigger than 14 if you got a 14mm intake...would a 14 bing slipppy on that?
ported gila+estoril+vm18+nice reeds+yellow springs 13x32
its the best- it takes off quick off the like and roars to 53
Reliable 40mph will be to put a kit like a cheap 43.5mm Airsal, stock carb (or 15 SHA), stock 14mm intake + any non-huge pipe.
Thanks for your input fellas.
While I wait for my MLM sidebleed and reed kit (.28mm) from treatland I put on the 14mm Morini intake, SHA metal screen / black cap air filter, and upjetted to 58. Took it for a spin and it did about 28mph - slightly improved from stock.
When I put the new pipe and reeds on I'll upjet to the mid 60s or so. Bought a range of 60 jets and I dont foresee needing more than that for the time being.
Believe stock gearing is 13/32 unless I counted the rear wrong in a hurry. Any idea where I can get a rear sprocket for this? Believe I saw a 13 and 14 tooth front sprocket on sale from treatland.
I'm curious to see what speed the upgraded intake, reeds, filter, exhaust and upjetting can get me to. I want to give these a try before doing any kind of kitting
Thanks again
Andrew
Update on this. Put the all the parts on and the bike is moving along well to 35mph. Those blue springs and pipe helped a lot. Anyone have any suggestions to get it over that 40mph mark? Aside from kitting / porting. I'll leave those ideas for the winter once I take everything apart to replace the seals, bearings, etc. With the mods I mentioned before I'm currently at a 65 jet which I'm not 100% sure is right.
Thanks all
Andrew
just a pipe? jetting it too high
carb came with a 52 normally stock, with a pipe i would go to 56-58 jet only especially with the SHA14.12 on it . maybe 60 tops, check the plug for color. also how much oil are you running per gallon?
Pipe, 14mm intake (came with the 9mm), upgraded reeds, and metal mesh air filter
Running Amsoil Saber 80:1 (edited)
Heres the plug. Looks on the rich side
Might try the 63 and 61 jets with new plugs once they get here
