Dellorto PHBN needle listing with angles
Michael Forrest /
For considering a needle change of course you need to know the taper angle. More angle contributes more gas at full throttle and less angle less gas. Hopefully soon I will also calculate angles for the other Dellorto carbs.
Re: Dellorto PHBN needle listing with angles
Michael Forrest /
In my hurry I made some mistakes but here it is corrected: (edited)
Most excellent chart - its a keeper
Ungapped rings to bind them all /
Thanks!
Overpriced Parts /
How about Dellorto PHBG carbs even though I know that the two needles you need for most kits! And you don’t know cause you didn’t have over 200 2 cycle bikes go through your hands over the years!
Reed kit#7 needle
Piston port # 9 to 7 needle
> Reed kit#7 needle
Haha yes that’s the only two needles I know about and care about.
The w12 is sometimes worth a try in phbg minarelli, but i have a w7 in mine too
> Reed kit#7 needle
I've also used w16
The phbg needle chart might be in the wiki? Idk but it shouldnt be hard 2 find. I seen it around fo sho.
Dirty30 Dillon /
> Reed kit#7 needle
You really gotta get a new schtick.
Depending on atomizer size the needle you need varies.
Mikey Antonakakis /
There's hardly any variance in atomizer side compared to needle size - like 0.06 or 0.08mm for the full range? Compare that to the range of needle tip diameters, which goes from like 0.6mm to 1.8mm, so a range of 1.2mm by swapping needles vs. 0.06mm by swapping atomizers. So atomizer size doesn't determine needle size...
Mikey Antonakakis /
> Reed kit#7 needle
Just tried a W11, worked wonders for me with its fat tip, ripper 50cc reed engine. Might be due to my altitude. Stock setup for my engine uses W9.
