Dellorto PHBN needle listing with angles
Michael Forrest /
For considering a needle change of course you need to know the taper angle. More angle contributes more gas at full throttle and less angle less gas. Hopefully soon I will also calculate angles for the other Dellorto carbs.
Re: Dellorto PHBN needle listing with angles
Michael Forrest /
In my hurry I made some mistakes but here it is corrected:(edited)
Most excellent chart - its a keeper
Thanks!
Overpriced Parts /
How about Dellorto PHBG carbs even though I know that the two needles you need for most kits! And you don’t know cause you didn’t have over 200 2 cycle bikes go through your hands over the years!
Reed kit#7 needle
Piston port # 9 to 7 needle
> Reed kit#7 needle
Haha yes that’s the only two needles I know about and care about.
The w12 is sometimes worth a try in phbg minarelli, but i have a w7 in mine too
> Reed kit#7 needle
I've also used w16
The phbg needle chart might be in the wiki? Idk but it shouldnt be hard 2 find. I seen it around fo sho.
Dirty30 Dillon /
> Reed kit#7 needle
You really gotta get a new schtick.
Depending on atomizer size the needle you need varies.
Mikey Antonakakis /
There's hardly any variance in atomizer side compared to needle size - like 0.06 or 0.08mm for the full range? Compare that to the range of needle tip diameters, which goes from like 0.6mm to 1.8mm, so a range of 1.2mm by swapping needles vs. 0.06mm by swapping atomizers. So atomizer size doesn't determine needle size...
Mikey Antonakakis /
> Reed kit#7 needle
Just tried a W11, worked wonders for me with its fat tip, ripper 50cc reed engine. Might be due to my altitude. Stock setup for my engine uses W9.
Want to reply to this thread?
