Tomos A3
Was just wanting to upjet and put a different pipe on my stock A3. But the pipe suggested ,gets in the way of the pedal from what I've read, but still kicks starts. But I think after so many kicks to the head, so to speak, something's gonna break. Supposedly you can bend the pedal crank. But I straightened out my kickstand and that was bad enough. So does anyone know of a pedal crank that would clear or a different pipe .BTW, that was a techno boss pipe for A3 /A35. Thanks, ill keep looking! (edited)
Re: Tomos A3
get a pedal extension
Re: Tomos A3
Never knew they existed Pat, I look for it ,Thanks! Just a thought. I think the pedal isn't the problem, it's the inside face of the crank, isn't it? (edited)
Re: Tomos A3
Is your pedal arm already bent? The boss is a small pipe, so I think it should clear. You can install pedal arms with a bit more offset if you like. (edited)
Re: Tomos A3
Well somebody said their pedal keeps hitting on their A3 , but I kept scouring the sites and found the pipe at DOS.
