Re: General 5-Star Build - Fast 50cc Single-speed
Mikey Antonakakis /
Chapter 2 - Moving Away, Planning, and Starting
After chopping it all up, it did get a nice layer of phosphoric acid (Prep-n-Etch), because I knew I would be moving soon, and probably wouldn't work on it for a while. I was right about that.
I moved to Colorado in August 2015 to live with my now-wife. This meant the "mopeds are job one" life would be ending, and compromise would be introduced (bye No-nos! Thanks Kim and Sam and Brad and everyone else for helping me get prepped and moved).
Basically, things sat for almost another year, but once settled in I came up with a sketch for the build, literally:
I then moved on with the initial fab work. First step was to build some new motor mounts. By this point I had ordered wheels, sprocket, axles, brakes, spacers, etc., but it was kinda tricky to confidently get everything placed and spaced, when I had neither a mounted engine for spacing the sprocket on the axle, nor an assembled wheel/axle/brake/sprocket to space the engine. It was highly iterative, with lots of dimensional stack-up to calculate the correct spacings on both wheel-side and engine-side (I wanted better than just eyeballing it).
If you notice in the before/after photos of the chopped up frame, the big vertical motor mount plates were cut back quite a bit - this was in an effort to get the output sprocket as close to the swingarm pivot as possible (vertically and longitudinally) to ensure the best chain geometry.
Anyway, the motor mounts ended up being sorta simple, 1/8" bar stock and like 1/2" x 1" rectangular tubing from Home Depot, some doubled up to get the right spacing:
  General 5-Star Build - Fast 50cc Single-speedTopic by: Mikey Antonakakis Mikey Antonakakis 09/03/19 03:20PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 03:32PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 04:14PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 04:21PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 04:46PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Overpriced Parts Overpriced Parts 09/03/19 05:10PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 05:19PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:08PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:22PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:32PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:41PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:49PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:55PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:59PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 07:05PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 07:13PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 07:43PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Aaron Blair Aaron Blair 09/03/19 09:23PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Johnnie Distefano Johnnie Distefano 09/04/19 12:39PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/04/19 03:44PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Chris Squid Chris Squid 09/04/19 08:25PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: ken gilbert ken gilbert 09/05/19 05:32AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 11:03AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 11:23AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 11:39AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 11:47AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:07PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:19PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:25PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:32PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:37PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:43PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 09/05/19 12:44PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 02:17PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: alex . alex . 09/05/19 02:03PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 02:20PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 02:26PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: ken gilbert ken gilbert 09/05/19 02:22PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 02:33PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 02:41PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 03:09PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 03:15PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 03:47PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/06/19 01:18AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/06/19 01:46AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/12/19 11:03PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/14/19 10:21PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Born to be WillD Born to be WillD 09/18/19 07:33PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/18/19 07:49PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Alex Hedrick Alex Hedrick 09/21/19 02:30PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/21/19 10:16PM
