Chapter 7 - Seat Mounts
As you might have noticed, I got a fiberglass seat from Treats. These have no mounting provisions, so I added some aluminum bar stock to span across the bottom of the seat in the rear and fiberglassed it into place. Also added a couple c-shaped guys in the front to engage into some posts that live on the frame. No good pictures of those, sorry. The front things didn't end up being needed, but they at least align things for assembly.
As for the frame, I used some angle to make the front mount for the seat:
The rear used bar stock, but the section of frame it mounted to was actually a little out of alignment. Had to shim it up on the right side, which is why the weld looks like it was wandering - it actually just had to span a gap on the right side:
