Re: General 5-Star Build - Fast 50cc Single-speed
Mikey Antonakakis /
Chapter 20 - Wiring Issue
After the quick test run in the previous crappy video, I finished up the wiring. One minor issue with it, that's my own fault: I used pin 87a on the gauges' relay (instead of 87), which I understood to be powered up when you switch off the relay - this seems to be a correct assumption, as the switch worked as I hoped, but there was one issue. Left the battery plugged in, with everything powered down, for a couple days. After a day or so, no problem, still had enough juice that the lights worked, but the gauges seemed intermittent. But when I took the bike out to shoot the upcoming video, the battery had totally died. One of the cells (3S LiPo) is totally gone, couldn't rescue it, won't hold any amount of charge. So no working gauges in the next vid.
As for diagnosing the issue, with everything powered down and no battery connected, the battery terminals had 88 Ohm resistance, and with the switch in the on position, something like like 15k Ohm - oops, that's a 130mA draw when everything is shut off, meaning the 5000mAh battery would last about a day and a half with everything powered off! Must be that by using 87a, the relay routes power to the gauges when its coil is off - i.e. when I turn off the gauges, I'm powering the switching coil in the relay.
Should be an easy fix, just swap the connector to the 87 slot in the relay holder. The reason I used 87a in the first place was so my switches were all "down for off" because the gauge switch had to be upsidedown to fit between the gauges. So no biggie.
Video has a few more minutes to finish uploading, so coming soon!
  General 5-Star Build - Fast 50cc Single-speedTopic by: Mikey Antonakakis Mikey Antonakakis 09/03/19 03:20PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 03:32PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 04:14PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 04:21PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 04:46PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Overpriced Parts Overpriced Parts 09/03/19 05:10PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 05:19PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:08PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:22PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:32PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:41PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:49PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:55PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 06:59PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 07:05PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 07:13PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/03/19 07:43PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Aaron Blair Aaron Blair 09/03/19 09:23PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Johnnie Distefano Johnnie Distefano 09/04/19 12:39PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/04/19 03:44PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Chris Squid Chris Squid 09/04/19 08:25PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: ken gilbert ken gilbert 09/05/19 05:32AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 11:03AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 11:23AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 11:39AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 11:47AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:07PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:19PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:25PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:32PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:37PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 12:43PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 09/05/19 12:44PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 02:17PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: alex . alex . 09/05/19 02:03PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 02:20PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 02:26PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: ken gilbert ken gilbert 09/05/19 02:22PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 02:33PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 02:41PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 03:09PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 03:15PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/05/19 03:47PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/06/19 01:18AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/06/19 01:46AM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/12/19 11:03PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/14/19 10:21PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Born to be WillD Born to be WillD 09/18/19 07:33PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/18/19 07:49PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Alex Hedrick Alex Hedrick 09/21/19 02:30PM
  Re: General 5-Star Build - Fast 50cc Single-speedRe: Mikey Antonakakis Mikey Antonakakis 09/21/19 10:16PM
