Re: Shocko kit with proma circuit pipe jet size recommendations
Jacob Dolezal /
I got the proma on with a little wiggle here and there. It doesn't hit my kick stand, so that's nice. I used a dremel to cut two ¼ inch slots on either side to the end of the pipe to slightly reduce the size of the trip so that the baffle would fit over it then tapped it with a hammer to snug it up a little farther.
I put an 80 jet in the carb.
I still have the stock sir box on with a foam insert that was wrung with 5w-30. Is that a big problem?
I took it for a short ride and haven't gotten to WOT but it seems so far so goooooooood. I'm sure I'll just leave the shocko off.
Also picked up a new meatier rear tire and changed the rear oil. 75cc(2.5 ounces) of 80w gear oil.
Are there any possible problems that I need to keep my eye out for? (edited)
