Hobbit belt slip at 45
Terbo Speghetti /
So I've tried all the different belts, including the Mitsuboshi OEM one from treats, and I still slip when I hit around 43-5mph. I've still got loootttsss of RPMs left to go. I can tell because the engine revs way out as soon as it slips, and my ear dyno says I'm maybe 2/3 of the way thru the pipe. As soon as I let off the throttle, I can feel it hook right back up and I can accelerate for a sec until it happens again.
Bike setup is polini kit / oko 24 / Vforce / TJT / DOS ramp plate / simo calibrata pipe
What are you 60mph Hobbit people doing? Ramp plate spacers? Grinding out rivets in the pulley?
Give up your secrets plz! (edited)
Re: Hobbit belt slip at 45
Terbo Speghetti /
My only current theory is that my stock contra is tired and gives TOO much, so there's space for the belt to slip. But maybe that's crazy, I dunno. (edited)
ramp plate spacer for sure, but wheres your wheel adjusted to? Are you sitting 1-2mm below the rear pulley?
Terbo Speghetti /
I've set it both at the end and 2mm deep. With all the different belts.
Strong engine with a weak contra will slip a belt
Terbo Speghetti /
Right on, thanks for confirming my suspicion. Don't remember where I read it, but I recall you saying the red and yellow contras on treats are too girthy when compressed. Am I stuck with a stock replacement?
