> Daniel '' Wrote:
> I didn’t knew you were using the puch internal ignition coil as an
> ignition coil, I mean to use the normal ignition coil with 2 wires)blue
> and blue/black) as a 12v lighting coil. But if you already ordered up a
> freshie just go with that. I seem to remember havi to grind a bit off
> the corners to get it to not scrape, but it was so long ago now I don’t
> even remember.
I just got the 2.0 lighting coil in and it fits like a glove. Just had to stack some washers under it. Why does no one recommend this?
