Here are some speed results from today. The first one is mostly uphill and limiting.
What goes up must come down. I always like heading home. Its almost always down hill. I did swap to an AX profile belt on my return just for shits since my normal 4L340W belt is pretty worn and was goating hard from a stop. AX fixed the goating a good bit but it is just about the same as a good condition. It is a little slower on the low speed acceleration.
Anyways, I grabbed a recorded 47mph on the AX belt which is my top so far. I'm almost certain I went faster last night.
My previous best was 45 on a long downhill on the stock top end with the exhaust lip removed. Progress is good. I'm gonna try to run the same downhill again with the 4L340W belt and see if it's any better. The quality of the Gates AX belt is much higher than the 4L340W belts I've been using. They seem to vibrate a lot less.
