I'm casting another cylinder
I did a 50cc cylinder a decade ago:
http://team-nerdspeed.blogspot.com/2009/07/custom-cylinder-cast.html
And I've been working on a 75cc direct replacement for the Gilardoni cylinder, except more ports, bigger transfers and more aggressive port timing figures. I poured my first test on Sunday, which I thought was a total failure. I cracked the mold yesterday and it turns out it was a failure, but not by much. I'm going to make some changes to my burnout process and mold design and try again soon.
I mostly update my instagram @joshspaceman, but figured I should share here as well.
Re: I'm casting another cylinder
Awesome! Please keep it picture heavy and up to date for non instas.
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
can't wait to see this rip
That^ . Please .
Insta what ??? ;)
Jack Rutherford /
instagram users
> Jack Rutherford Wrote:
> instagram users
I know ... Just kidding . ;)
I don't use Instagram , like a lot of other sites I never visit .
Douglas Binder /
Looks pretty close to me. Will you plate it or use an iron sleeve? I tried plating mine but the plating failed so when I get back to that project, I'll just sleeve it and call it good.
Johnnie Distefano /
This is awesome!
𝐿𝑖𝑘𝑎-𝐿𝑜𝑡𝑎𝑠𝑎𝑢𝑟 𝑀𝑒𝑔𝑎𝑝𝑢𝑠 🦖 /
Whuddup Josh, heck yeah I like those big fins.
That think will rip, and I'll be first in line. I have production conections in China. Holler at ya boi.
awesome!
cool to see this getting bumped
Thanks everybody. Doug - I'm going to have it / them professionally plated & honed. I know that nikasil is actually a somewhat simple process on paper, but I know there's finesse in getting it right. Same goes for honing, so I will be working with a Pro on those aspects when we get there.
Here's a bunch of pictures, but a note on process. I read everything, all the books, weirdo Kart / Snowmobile / Jetski / RC Forums , the undisputed 2-Stroke beast designer that is Jan Thiel & his lovely Aprilia RSA engine... and try to reverse engineer existing designs to see what actually works in reality. When In doubt, I crack open Two Stroke Performance Tuning 2nd Edition by A. Graham Bell for cheat sheets.
The first cylinder I made in Seattle was basically a one-shot only art project. Which was dumb, but now I know better. This current design was figured out with math and formulas and copycatting. I drew up a port map, designed the cylinder in 3D, then produced 3D prints of the model with mold registrations already built in. I made silicone RTV molds of the ports (insides) and the cylinder (outsides). The port internals are cast in a sand/plaster mix, assembled then plugged into the mold. The mold is closed up and filled with hot wax. Basically Lost wax process from here on out.
more pics
even more pics
yet more pics
first cast test result
A dab of JbWeld and run it! ;)
Have You thought about useing a Yamaha jog 100cc piston? They are 48mm!
Douglas Binder /
You probably know this but getting the sprues as high as possible improves the fill and detail. Good luck. It's really great seeing someone else doing this. Alex and I had trouble with porosity (tiny holes on the cast that show themselves when you machine the bore). Please let us know if you solve that one. Because I plan to go with an iron sleeve, it doesn't matter to me but I would like to understand it. I won't get back to my cylinder till my airplane is done and that might take years!
> take years!
Are you talking about an airplane that u will be piloting? Plz say yes
>>>taykoff [s2m] /
Inspiring work. Even more impressed that you did this in Sketchup...look forward to seeing this rip!
Yo, you know they sell Gila kits on Treats right?
Kidding, badass work.
Douglas Binder /
Rocco, yes. Kitfox II.
All you people chiming in how you want one... a eurokit and a dio reed adaptor will have you ripping your god damn dong off.
For those playing at home, shrinkage is running about 2% in the thinner parts and 5% in the thicker sections. I may make some changes to the mold if improvements in the burnout process don't yield better accuracy.
Also here's a side by side look of the first test with a trashed Gilardoni I have laying around.
wow it’s a lot of work .. time you get it right all 3 girls you ever dated will be on social security...
Overpriced Parts /
You are a true trooper/purpose but you’re wasting your time, By the time you think of it 100 people think of it when you think of anything it already has been done
This is crazy to me that people are saying it is a waste of time. It seems he is more into this for the process then an easy way to get an end result. I think it has been fun just watching him post his results.
