Mutant Manual Sachs Trike Build
Aaron Goldman /
Hello all!
Figured this build was worth a post. I'm going to be building another moped with my 6th grade students this year and wanted to do something weird. Well, I have some old advertisements for Trike mopeds and my students and I thought, WHAT COULD BE WEIRDER! So a Trike became the plan.
Recently I purchased a Pryor Trike rear end from DMW which necessitated an engine with pedals integrated. Considering I thoroughly enjoy working on Sachs, have lots of parts and tools for them as well as Sachs being the red-headed step child of Mopeds, the 505 engine was chosen.
This build will likely have slow progress until after New Years. We are still collecting parts.
So far what we have is two 505/2 manual shift engines to smoosh into 1 functioning motor. I'm getting a built crank from a friend as well as a bunch of other Sachs parts he doesn't need anymore.
I have an old Airsal kit that I blew up once which will be going onto the 505/2 with a new piston. We will be attempting to shove a 7-piece clutch set into the engine with an extra diaphragm spring to help with shifting into second. Currently I have a 14mm bing hanging around so we will probably throw that on to begin with.
Additionally due to the recent post by Graham about a weird Sachs cylinder I have discovered the existence of the bizarre Sachs stock Boner pipe. Toledo said he may have one floating around so I'm hoping to get that on the engine as well and use a clamp on expansion chamber as well as a butterfly to control the boner(butterflies get me going).
The plan for the trike is to build a flatbed with removeable bedsides to maximize storage space. The weight is my main concern and I refuse to build the entire thing out of Plywood so we will have to be creative to save on weight. The weight is the main reason for the kit and clutch upgrade. I personally am very light 145 soaking wet, but with the bed loaded up...yikes.
Hoping to use the rear "coaster" brake setup for the trike differential brake. Not sure if I will need a disc in the front or if the drum will suffice.
The shifting is going to be done Jockey Shift style with a rod and cable. Thankfully I'm a blacksmith so I should be able to fab the linkage fairly easily. I plan on putting a brake lever on the top of the rod to act as the clutch lever. No clue how that's gonna turn out.
Currently still trying to find/decide on a frame. I have a possible line on a columbia commuter but I'm not 100% sure that will happen.
I'll try to post some photos as things come together.
Looking for any other weird suggestions for this trike; the more bizarre Sachs crap I can put on it the better. Stay tuned, hoping this will be interesting. (edited)
  Mutant Manual Sachs Trike BuildTopic by: Aaron Goldman Aaron Goldman 12/09/19 11:12AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/09/19 01:17PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/09/19 02:32PM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/09/19 03:41PM
  Re: Mutant Manual Sachs Trike BuildRe: * * * * 12/09/19 10:48PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/10/19 06:57AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/12/19 04:40PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 05:36PM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/12/19 05:43PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 06:59PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 07:04PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/13/19 01:51PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/03/20 01:44PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/06/20 08:19AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/06/20 02:46PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/17/20 09:06AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/20/20 09:58AM
  Re: Mutant Manual Sachs Trike BuildRe: Dirty30 Dillon Dirty30 Dillon 03/06/20 09:24AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 12/12/19 03:02PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/13/19 03:03PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/16/19 06:51PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 12/16/19 08:20PM
  Re: Mutant Manual Sachs Trike BuildRe: * * * * 12/12/19 05:06PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Blair Aaron Blair 01/18/20 04:43PM
  Re: Mutant Manual Sachs Trike BuildRe: EH FCC of the QCB EH FCC of the QCB 01/18/20 05:14PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/19/20 09:40AM
  Re: Mutant Manual Sachs Trike BuildRe: Daniel '' Daniel '' 01/19/20 12:52PM
  Re: Mutant Manual Sachs Trike BuildRe: Daniel '' Daniel '' 01/19/20 03:03AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/20/20 09:22AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/06/20 09:00AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/06/20 11:13AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 03/06/20 11:24AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/07/20 12:01PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/07/20 01:00PM
  Re: Mutant Manual Sachs Trike BuildRe: Dirty30 Dillon Dirty30 Dillon 03/10/20 10:09AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/10/20 10:17AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/09/20 03:43PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 05:18PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 05:34PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/20 05:37PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/09/20 06:26PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 06:47PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/11/20 08:35AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/12/20 01:54PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/12/20 07:05PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/13/20 09:18AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/13/20 06:52PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/15/20 02:37PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/17/20 02:01PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/17/20 02:17PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/17/20 02:28PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/30/20 09:23AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 04/04/20 06:02PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/27/20 06:47PM
