Re: Mutant Manual Sachs Trike Build
DrGeorgeTompson (Alan) /
> Born to be WillD Wrote:
> dirt church alan did a footshift on a sachs manual, that info is around
> somewhere.
Ye, here's that thread
I had 3 clutch pads in it and 2 springs. I replaced the thick elliptical? washer on the end of the clutch stack with a thinner one and added a spacer to the cover. It held up rather well after I used lock nuts on the clutch to keep it from spinning off. double spring and extra parts held the 24mm and 80cc kit wide open all the time.
If you dont gear it to try and go 1000 miles an hour, the modified clutch does fairly well. I tried pretty hard to lock the clutch up as soon as possible though. Once it dropped from a 13 tooth front sprocket to 11 it was much more manageable and enjoyable to ride. The trike weight may cause problems. idk. It's a cool project and i think it should work out.
Foot shift was neat cause you could kinda jam it into 2nd since it doesnt really like to fall in at high rpm.
That motor is just sitting on a shelf now. Maybe i'll bring it back out some day. (edited)
  Mutant Manual Sachs Trike BuildTopic by: Aaron Goldman Aaron Goldman 12/09/19 11:12AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/09/19 01:17PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/09/19 02:32PM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/09/19 03:41PM
  Re: Mutant Manual Sachs Trike BuildRe: * * * * 12/09/19 10:48PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/10/19 06:57AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/12/19 04:40PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 05:36PM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/12/19 05:43PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 06:59PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 07:04PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/13/19 01:51PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/03/20 01:44PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/06/20 08:19AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/06/20 02:46PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/17/20 09:06AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/20/20 09:58AM
  Re: Mutant Manual Sachs Trike BuildRe: Dirty30 Dillon Dirty30 Dillon 03/06/20 09:24AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 12/12/19 03:02PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/13/19 03:03PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/16/19 06:51PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 12/16/19 08:20PM
  Re: Mutant Manual Sachs Trike BuildRe: * * * * 12/12/19 05:06PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Blair Aaron Blair 01/18/20 04:43PM
  Re: Mutant Manual Sachs Trike BuildRe: EH FCC of the QCB EH FCC of the QCB 01/18/20 05:14PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/19/20 09:40AM
  Re: Mutant Manual Sachs Trike BuildRe: Daniel '' Daniel '' 01/19/20 12:52PM
  Re: Mutant Manual Sachs Trike BuildRe: Daniel '' Daniel '' 01/19/20 03:03AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/20/20 09:22AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/06/20 09:00AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/06/20 11:13AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 03/06/20 11:24AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/07/20 12:01PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/07/20 01:00PM
  Re: Mutant Manual Sachs Trike BuildRe: Dirty30 Dillon Dirty30 Dillon 03/10/20 10:09AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/10/20 10:17AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/09/20 03:43PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 05:18PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 05:34PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/20 05:37PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/09/20 06:26PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 06:47PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/11/20 08:35AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/12/20 01:54PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/12/20 07:05PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/13/20 09:18AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/13/20 06:52PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/15/20 02:37PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/17/20 02:01PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/17/20 02:17PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/17/20 02:28PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/30/20 09:23AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 04/04/20 06:02PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/27/20 06:47PM
