Re: Mutant Manual Sachs Trike Build
Aaron Goldman /
So I’m planning for everything. Spoke to a few people, read a few things, made a plan for the clutch....cool it.
Assuming heat is a major factor in glazing the pads, this should help reduce that and allow me to slip the clutch.
Upon recommendation by j-bot I’ll be cooling the head with water as well; using the 1977 head I should be able to keep the engine frosty. This will hopefully allow me to manage my clutch temps using an aluminum waterblock([url=http://Yobett Aluminum Water Cooling Blocks for CPU Heatsink Cooler Plater 41x 41 X 12mm
[url=https://www.amazon.com/dp/B00DHC2GJ6/?tag=mopedarmy-20]https://www.amazon.com/dp/B00DHC2GJ6/[/url]
]Yobett Aluminum Water Cooling Blocks for CPU Heatsink Cooler Plater 41x 41 X 12mm
[/url]
with a Peltier cooler and a heat sink...maybe?
Not sure on the peltier yet but will definitely be putting an aluminum water lock under the clutch area of the case.
It is unfortunate to be limited by aluminum. In the computer cooling world there are tons of copper/nickel options for cooling.
  Mutant Manual Sachs Trike BuildTopic by: Aaron Goldman Aaron Goldman 12/09/19 11:12AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/09/19 01:17PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/09/19 02:32PM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/09/19 03:41PM
  Re: Mutant Manual Sachs Trike BuildRe: * * * * 12/09/19 10:48PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/10/19 06:57AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/12/19 04:40PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 05:36PM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/12/19 05:43PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 06:59PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 07:04PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/13/19 01:51PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/03/20 01:44PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/06/20 08:19AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/06/20 02:46PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/17/20 09:06AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/20/20 09:58AM
  Re: Mutant Manual Sachs Trike BuildRe: Dirty30 Dillon Dirty30 Dillon 03/06/20 09:24AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 12/12/19 03:02PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/13/19 03:03PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/16/19 06:51PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 12/16/19 08:20PM
  Re: Mutant Manual Sachs Trike BuildRe: * * * * 12/12/19 05:06PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Blair Aaron Blair 01/18/20 04:43PM
  Re: Mutant Manual Sachs Trike BuildRe: EH FCC of the QCB EH FCC of the QCB 01/18/20 05:14PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/19/20 09:40AM
  Re: Mutant Manual Sachs Trike BuildRe: Daniel '' Daniel '' 01/19/20 12:52PM
  Re: Mutant Manual Sachs Trike BuildRe: Daniel '' Daniel '' 01/19/20 03:03AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/20/20 09:22AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/06/20 09:00AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/06/20 11:13AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 03/06/20 11:24AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/07/20 12:01PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/07/20 01:00PM
  Re: Mutant Manual Sachs Trike BuildRe: Dirty30 Dillon Dirty30 Dillon 03/10/20 10:09AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/10/20 10:17AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/09/20 03:43PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 05:18PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 05:34PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/20 05:37PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/09/20 06:26PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 06:47PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/11/20 08:35AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/12/20 01:54PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/12/20 07:05PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/13/20 09:18AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/13/20 06:52PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/15/20 02:37PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/17/20 02:01PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/17/20 02:17PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/17/20 02:28PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/30/20 09:23AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 04/04/20 06:02PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/27/20 06:47PM
