Re: Mutant Manual Sachs Trike Build
Aaron Goldman /
Unfortunately you can’t mix copper and aluminum in a water loop, get a reaction that costs the inside of the radiator and waterblock(head in this case).
My other concern is the “plastic” piece had groove protruding in the shape of the radiators loop. I’m wondering if that separates the channel from just running together through the open space. I’m not sure how well it will seal that area without the plastic.
Possibly some thing aluminum sheet could be made into a gasket?
Definitely correct thinking that the backplate offers limited cooling benefit. Nonetheless a benefit if I can make it more efficient.
The other major thing I noticed is this radiator is really only cooled by blowing through those open slots in the middle. If this radiator is mounted parallel to the frame, or right up against the underside of the tank, it won’t cool efficiently.
It’s seems between the forks or something similar is key, doing that with an efficient thermosiphon will be a PITA.
  Mutant Manual Sachs Trike BuildTopic by: Aaron Goldman Aaron Goldman 12/09/19 11:12AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/09/19 01:17PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/09/19 02:32PM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/09/19 03:41PM
  Re: Mutant Manual Sachs Trike BuildRe: * * * * 12/09/19 10:48PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/10/19 06:57AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/12/19 04:40PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 05:36PM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 12/12/19 05:43PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 06:59PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/12/19 07:04PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/13/19 01:51PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/03/20 01:44PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/06/20 08:19AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/06/20 02:46PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/17/20 09:06AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 01/20/20 09:58AM
  Re: Mutant Manual Sachs Trike BuildRe: Dirty30 Dillon Dirty30 Dillon 03/06/20 09:24AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 12/12/19 03:02PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 12/13/19 03:03PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 12/16/19 06:51PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 12/16/19 08:20PM
  Re: Mutant Manual Sachs Trike BuildRe: * * * * 12/12/19 05:06PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Blair Aaron Blair 01/18/20 04:43PM
  Re: Mutant Manual Sachs Trike BuildRe: EH FCC of the QCB EH FCC of the QCB 01/18/20 05:14PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/19/20 09:40AM
  Re: Mutant Manual Sachs Trike BuildRe: Daniel '' Daniel '' 01/19/20 12:52PM
  Re: Mutant Manual Sachs Trike BuildRe: Daniel '' Daniel '' 01/19/20 03:03AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 01/20/20 09:22AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/06/20 09:00AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/06/20 11:13AM
  Re: Mutant Manual Sachs Trike BuildRe: Graham Motzing Graham Motzing 03/06/20 11:24AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/07/20 12:01PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/07/20 01:00PM
  Re: Mutant Manual Sachs Trike BuildRe: Dirty30 Dillon Dirty30 Dillon 03/10/20 10:09AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/10/20 10:17AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/09/20 03:43PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 05:18PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 05:34PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/09/20 05:37PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/09/20 06:26PM
  Re: Mutant Manual Sachs Trike BuildRe: P D P D 03/09/20 06:47PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/11/20 08:35AM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/12/20 01:54PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/12/20 07:05PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/13/20 09:18AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/13/20 06:52PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/15/20 02:37PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/17/20 02:01PM
  Re: Mutant Manual Sachs Trike BuildRe: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 03/17/20 02:17PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/17/20 02:28PM
  Re: Mutant Manual Sachs Trike BuildRe: Born to be WillD Born to be WillD 03/30/20 09:23AM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 04/04/20 06:02PM
  Re: Mutant Manual Sachs Trike BuildRe: Aaron Goldman Aaron Goldman 03/27/20 06:47PM
