Not much of an update but excited to get this going.
Since I had polini cases and this has the malossi ones I'll have to remake some lunch lever/water pump brackets.
Plan on using a doppler pipe with the Stsge6 so I'll make an adapting exhaust flange for the time being. 28mm ID vs doppler 26mm, might lose some power but this is for testing purposes after all. That all should be relatively easy.
Next challenge is getting the PWK carb to fit. Subframe barely fits the phbg so I think it'll have to swing out the side for clearance. Anyone ever do something like that before?
