> Lee Pinkerton Wrote:
> Not much of an update but excited to get this going.
> Since I had polini cases and this has the malossi ones I'll have to
> remake some lunch lever/water pump brackets.
> Plan on using a doppler pipe with the Stsge6 so I'll make an adapting
> exhaust flange for the time being. 28mm ID vs doppler 26mm, might lose
> some power but this is for testing purposes after all. That all should
> be relatively easy.
> Next challenge is getting the PWK carb to fit. Subframe barely fits the
> phbg so I think it'll have to swing out the side for clearance. Anyone
> ever do something like that before?
hmmmm yo could just send me that old motor, I just built a similar bottom end, but I used Teknix cases, I ported the intake and think I fucked myself, I dont like the sound its making upon start up....
