Re: Stage6 MK1 Peugeot Engine
Daniel '' /
50# might be fine for a Stock moby or Peugeot variator, they have well over 40 grams of weight in there. I have found that a shock and spring together is the best. A spring tends to jump back to fast and a shock is too linear. It won’t keep the rpms up if the right lbs or will shift slow with too much lbs, using both gives you the increase in tension as you variate and the smoothness of the gas shock. Naz has a sweet set up on his where he fit a spring around his shock. I just have a 20# shock and the stock spring.
  Stage6 MK1 Peugeot EngineTopic by: Pritza R&D Pritza R&D 12/24/19 12:23PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:28PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:33PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:37PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:40PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:44PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:49PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:53PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:57PM
  Re: Stage6 MK1 Peugeot EngineRe: JBOT Admin JBOT Admin 12/24/19 12:59PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:15PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:01PM
  Re: Stage6 MK1 Peugeot EngineRe: JBOT Admin JBOT Admin 12/24/19 01:06PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:05PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:09PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 12/25/19 04:00PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 12/25/19 04:54PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/25/19 05:40PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 12/25/19 06:05PM
  Re: Stage6 MK1 Peugeot EngineRe: scrot rash scrot rash 12/25/19 04:27PM
  Re: Stage6 MK1 Peugeot EngineRe: Roger Suarez Roger Suarez 12/25/19 07:49PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 12/25/19 10:13PM
  Re: Stage6 MK1 Peugeot EngineRe: Dirty30 Dillon Dirty30 Dillon 12/26/19 09:19AM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 12/28/19 05:13PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 12/28/19 08:17PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/06/20 11:23PM
  Re: Stage6 MK1 Peugeot EngineRe: scrot rash scrot rash 01/07/20 12:24PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/09/20 10:13PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/10/20 12:11PM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 01/10/20 02:06PM
  Re: Stage6 MK1 Peugeot EngineRe: JBOT Admin JBOT Admin 01/08/20 12:41PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 12/28/19 03:55PM
  Re: Stage6 MK1 Peugeot EngineRe: Born to be WillD Born to be WillD 01/07/20 09:25AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/12/20 09:00PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 01/12/20 11:32PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 01/13/20 08:14AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/13/20 10:40PM
  Re: Stage6 MK1 Peugeot EngineRe: EH FCC of the QCB EH FCC of the QCB 01/13/20 11:27PM
  Re: Stage6 MK1 Peugeot EngineRe: Graham Motzing Graham Motzing 01/15/20 05:58PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/15/20 08:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/15/20 08:08PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/21/20 11:01AM
  Re: Stage6 MK1 Peugeot EngineRe: Dirty30 Dillon Dirty30 Dillon 01/21/20 11:05AM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 01/21/20 02:35PM
  Re: Stage6 MK1 Peugeot EngineRe: reynie domingo reynie domingo 01/24/20 08:59PM
  Re: Stage6 MK1 Peugeot EngineRe: scrot rash scrot rash 01/25/20 07:28AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/21/20 11:05AM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/21/20 07:03PM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/21/20 07:10PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/21/20 09:04PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/22/20 10:36AM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 01/23/20 07:45PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/23/20 08:59PM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 01/23/20 10:35PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/24/20 01:51PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 01/22/20 12:12AM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/22/20 02:54PM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/25/20 02:39PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/06/20 09:23PM
  Re: Stage6 MK1 Peugeot EngineRe: P D P D 02/06/20 09:36PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 02/06/20 10:20PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/06/20 10:52PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 02/11/20 03:20AM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 02/06/20 11:37PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/10/20 10:16PM
  Re: Stage6 MK1 Peugeot EngineRe: EH FCC of the QCB EH FCC of the QCB 05/05/20 08:30AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/05/20 09:56AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/05/20 10:02AM
  Re: Stage6 MK1 Peugeot EngineRe: Ryan Graeme Ryan Graeme 05/05/20 11:57PM
  Re: Stage6 MK1 Peugeot EngineRe: Roger Suarez Roger Suarez 05/05/20 08:14PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 05/06/20 09:07AM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 05/06/20 01:42PM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 05/26/20 01:28PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 05/26/20 04:46PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 05/06/20 10:49AM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 05/06/20 01:43PM
  Re: Stage6 MK1 Peugeot EngineRe: Roger Suarez Roger Suarez 05/07/20 01:21AM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 05/19/20 08:04AM
  Re: Stage6 MK1 Peugeot EngineRe: P D P D 05/19/20 10:04AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/25/20 10:03PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/25/20 10:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/26/20 12:00PM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 05/27/20 02:26AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/27/20 09:36AM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 05/27/20 02:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 06/04/20 10:52AM
  Re: Stage6 MK1 Peugeot EngineRe: Dirty30 Dillon Dirty30 Dillon 06/04/20 02:09PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 06/05/20 11:40AM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 06/07/20 01:25AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 06/08/20 12:35PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/15/20 03:03PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/15/20 03:04PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/15/20 03:07PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/15/20 03:50PM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/16/20 11:03PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/17/20 10:06AM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/17/20 09:21PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 07/23/20 03:51PM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/24/20 06:54PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/24/20 08:16PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/24/20 08:37PM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/25/20 11:19AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/18/20 08:15PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 08/19/20 11:28AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/20/20 10:51PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/15/20 07:33PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/23/20 08:46PM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 08/18/20 10:57PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/22/20 08:35PM
  Re: Stage6 MK1 Peugeot EngineRe: Jesse Simonsen Jesse Simonsen 08/23/20 12:06AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/23/20 09:52AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/22/20 08:37PM
  Re: Stage6 MK1 Peugeot EngineRe: Jay Rivett Jay Rivett 08/23/20 10:29AM
  Re: Stage6 MK1 Peugeot EngineRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 08/23/20 04:04PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/24/20 11:19AM
  Re: Stage6 MK1 Peugeot EngineRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 08/24/20 02:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/31/20 02:38PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 03:05PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 03:11PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 01/05/21 08:33PM
  Re: Stage6 MK1 Peugeot EngineRe: Graham Motzing Graham Motzing 01/05/21 09:11PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 02/17/21 10:47PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/17/21 11:17PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 02/17/21 11:30PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 09:26PM
  Re: Stage6 MK1 Peugeot EngineRe: Graham Motzing Graham Motzing 01/05/21 09:41PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 09:57PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/17/21 05:30PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/17/21 05:37PM
  Re: Stage6 MK1 Peugeot EngineRe: Siezed Again Siezed Again 01/10/21 10:44AM
