Re: Stage6 MK1 Peugeot Engine
Michael Mike Naz /
You would need to do number of things to properly flip the variator. Let me know if you would like a couple photos.
It does move much of the mass off the end of the crankshaft and inboard towards the motor. While I am doing the lathe work to the inner section of the variator I also usually wander over to the mill and machine a new pocket into the doppler variator so it also properly keys to the crankshaft.
You would also need to machine your doppler clutch shoes and switch the clutch pulley to HFL3030 bearing. During the machining of the clutch shoes I usually counter-bore and tap some holes into the clutch shoes to allow for variator weights to be added or removed so you can also tune the clutch somewhat. This whole process allows the pulley to be pushed out a bit further from the bike to get better belt alignment. Also I run a thrust bearing stack on either side of the pulley. That also helps with belt alignment has the added benefit that it also cuts down on friction.
Last little thing is the rear sprocket needs a little spacing out as well to get it back in alignment after you just pushed pulley out with that thrust stack on the inboard side.
I do this same process to all these parts any time I use any of them.
Sorry for the long response and hopefully that all made sense since I kinda suck at writing
good luck on the project.
-Naz
  Stage6 MK1 Peugeot EngineTopic by: Pritza R&D Pritza R&D 12/24/19 12:23PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:28PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:33PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:37PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:40PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:44PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:49PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:53PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:57PM
  Re: Stage6 MK1 Peugeot EngineRe: JBOT Admin JBOT Admin 12/24/19 12:59PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:15PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:01PM
  Re: Stage6 MK1 Peugeot EngineRe: JBOT Admin JBOT Admin 12/24/19 01:06PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:05PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:09PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 12/25/19 04:00PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 12/25/19 04:54PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/25/19 05:40PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 12/25/19 06:05PM
  Re: Stage6 MK1 Peugeot EngineRe: scrot rash scrot rash 12/25/19 04:27PM
  Re: Stage6 MK1 Peugeot EngineRe: Roger Suarez Roger Suarez 12/25/19 07:49PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 12/25/19 10:13PM
  Re: Stage6 MK1 Peugeot EngineRe: Dirty30 Dillon Dirty30 Dillon 12/26/19 09:19AM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 12/28/19 05:13PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 12/28/19 08:17PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/06/20 11:23PM
  Re: Stage6 MK1 Peugeot EngineRe: scrot rash scrot rash 01/07/20 12:24PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/09/20 10:13PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/10/20 12:11PM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 01/10/20 02:06PM
  Re: Stage6 MK1 Peugeot EngineRe: JBOT Admin JBOT Admin 01/08/20 12:41PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 12/28/19 03:55PM
  Re: Stage6 MK1 Peugeot EngineRe: Born to be WillD Born to be WillD 01/07/20 09:25AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/12/20 09:00PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 01/12/20 11:32PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 01/13/20 08:14AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/13/20 10:40PM
  Re: Stage6 MK1 Peugeot EngineRe: EH FCC of the QCB EH FCC of the QCB 01/13/20 11:27PM
  Re: Stage6 MK1 Peugeot EngineRe: Graham Motzing Graham Motzing 01/15/20 05:58PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/15/20 08:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/15/20 08:08PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/21/20 11:01AM
  Re: Stage6 MK1 Peugeot EngineRe: Dirty30 Dillon Dirty30 Dillon 01/21/20 11:05AM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 01/21/20 02:35PM
  Re: Stage6 MK1 Peugeot EngineRe: reynie domingo reynie domingo 01/24/20 08:59PM
  Re: Stage6 MK1 Peugeot EngineRe: scrot rash scrot rash 01/25/20 07:28AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/21/20 11:05AM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/21/20 07:03PM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/21/20 07:10PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/21/20 09:04PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/22/20 10:36AM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 01/23/20 07:45PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/23/20 08:59PM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 01/23/20 10:35PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/24/20 01:51PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 01/22/20 12:12AM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/22/20 02:54PM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/25/20 02:39PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/06/20 09:23PM
  Re: Stage6 MK1 Peugeot EngineRe: P D P D 02/06/20 09:36PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 02/06/20 10:20PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/06/20 10:52PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 02/11/20 03:20AM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 02/06/20 11:37PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/10/20 10:16PM
  Re: Stage6 MK1 Peugeot EngineRe: EH FCC of the QCB EH FCC of the QCB 05/05/20 08:30AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/05/20 09:56AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/05/20 10:02AM
  Re: Stage6 MK1 Peugeot EngineRe: Ryan Graeme Ryan Graeme 05/05/20 11:57PM
  Re: Stage6 MK1 Peugeot EngineRe: Roger Suarez Roger Suarez 05/05/20 08:14PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 05/06/20 09:07AM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 05/06/20 01:42PM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 05/26/20 01:28PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 05/26/20 04:46PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 05/06/20 10:49AM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 05/06/20 01:43PM
  Re: Stage6 MK1 Peugeot EngineRe: Roger Suarez Roger Suarez 05/07/20 01:21AM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 05/19/20 08:04AM
  Re: Stage6 MK1 Peugeot EngineRe: P D P D 05/19/20 10:04AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/25/20 10:03PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/25/20 10:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/26/20 12:00PM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 05/27/20 02:26AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/27/20 09:36AM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 05/27/20 02:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 06/04/20 10:52AM
  Re: Stage6 MK1 Peugeot EngineRe: Dirty30 Dillon Dirty30 Dillon 06/04/20 02:09PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 06/05/20 11:40AM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 06/07/20 01:25AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 06/08/20 12:35PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/15/20 03:03PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/15/20 03:04PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/15/20 03:07PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/15/20 03:50PM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/16/20 11:03PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/17/20 10:06AM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/17/20 09:21PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 07/23/20 03:51PM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/24/20 06:54PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/24/20 08:16PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/24/20 08:37PM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/25/20 11:19AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/18/20 08:15PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 08/19/20 11:28AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/20/20 10:51PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/15/20 07:33PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/23/20 08:46PM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 08/18/20 10:57PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/22/20 08:35PM
  Re: Stage6 MK1 Peugeot EngineRe: Jesse Simonsen Jesse Simonsen 08/23/20 12:06AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/23/20 09:52AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/22/20 08:37PM
  Re: Stage6 MK1 Peugeot EngineRe: Jay Rivett Jay Rivett 08/23/20 10:29AM
  Re: Stage6 MK1 Peugeot EngineRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 08/23/20 04:04PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/24/20 11:19AM
  Re: Stage6 MK1 Peugeot EngineRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 08/24/20 02:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/31/20 02:38PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 03:05PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 03:11PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 01/05/21 08:33PM
  Re: Stage6 MK1 Peugeot EngineRe: Graham Motzing Graham Motzing 01/05/21 09:11PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 02/17/21 10:47PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/17/21 11:17PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 02/17/21 11:30PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 09:26PM
  Re: Stage6 MK1 Peugeot EngineRe: Graham Motzing Graham Motzing 01/05/21 09:41PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 09:57PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/17/21 05:30PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/17/21 05:37PM
  Re: Stage6 MK1 Peugeot EngineRe: Siezed Again Siezed Again 01/10/21 10:44AM
