Re: Stage6 MK1 Peugeot Engine
L e e /
Thanks Naz.
I have a spare er3, case, and doppler crank I can get started with. I'll probably do this on the side as it is more involved than anticipated. Then plop it on one day.
> Michael Mike Naz Wrote:
> You would need to do number of things to properly flip the variator. Let
> me know if you would like a couple photos.
> It does move much of the mass off the end of the crankshaft and inboard
> towards the motor. While I am doing the lathe work to the inner section
> of the variator I also usually wander over to the mill and machine a new
> pocket into the doppler variator so it also properly keys to the
> crankshaft.
> You would also need to machine your doppler clutch shoes and switch the
> clutch pulley to HFL3030 bearing. During the machining of the clutch
> shoes I usually counter-bore and tap some holes into the clutch shoes to
> allow for variator weights to be added or removed so you can also tune
> the clutch somewhat. This whole process allows the pulley to be pushed
> out a bit further from the bike to get better belt alignment. Also I run
> a thrust bearing stack on either side of the pulley. That also helps
> with belt alignment has the added benefit that it also cuts down on
> friction.
> Last little thing is the rear sprocket needs a little spacing out as
> well to get it back in alignment after you just pushed pulley out with
> that thrust stack on the inboard side.
> I do this same process to all these parts any time I use any of them.
> Sorry for the long response and hopefully that all made sense since I
> kinda suck at writing
> good luck on the project.
> -Naz
  Stage6 MK1 Peugeot EngineTopic by: Pritza R&D Pritza R&D 12/24/19 12:23PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:28PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:33PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:37PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:40PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:44PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:49PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:53PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 12:57PM
  Re: Stage6 MK1 Peugeot EngineRe: JBOT Admin JBOT Admin 12/24/19 12:59PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:15PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:01PM
  Re: Stage6 MK1 Peugeot EngineRe: JBOT Admin JBOT Admin 12/24/19 01:06PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:05PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/24/19 01:09PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 12/25/19 04:00PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 12/25/19 04:54PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 12/25/19 05:40PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 12/25/19 06:05PM
  Re: Stage6 MK1 Peugeot EngineRe: scrot rash scrot rash 12/25/19 04:27PM
  Re: Stage6 MK1 Peugeot EngineRe: Roger Suarez Roger Suarez 12/25/19 07:49PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 12/25/19 10:13PM
  Re: Stage6 MK1 Peugeot EngineRe: Dirty30 Dillon Dirty30 Dillon 12/26/19 09:19AM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 12/28/19 05:13PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 12/28/19 08:17PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/06/20 11:23PM
  Re: Stage6 MK1 Peugeot EngineRe: scrot rash scrot rash 01/07/20 12:24PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/09/20 10:13PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/10/20 12:11PM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 01/10/20 02:06PM
  Re: Stage6 MK1 Peugeot EngineRe: JBOT Admin JBOT Admin 01/08/20 12:41PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 12/28/19 03:55PM
  Re: Stage6 MK1 Peugeot EngineRe: Born to be WillD Born to be WillD 01/07/20 09:25AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/12/20 09:00PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 01/12/20 11:32PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 01/13/20 08:14AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/13/20 10:40PM
  Re: Stage6 MK1 Peugeot EngineRe: EH FCC of the QCB EH FCC of the QCB 01/13/20 11:27PM
  Re: Stage6 MK1 Peugeot EngineRe: Graham Motzing Graham Motzing 01/15/20 05:58PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/15/20 08:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/15/20 08:08PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/21/20 11:01AM
  Re: Stage6 MK1 Peugeot EngineRe: Dirty30 Dillon Dirty30 Dillon 01/21/20 11:05AM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 01/21/20 02:35PM
  Re: Stage6 MK1 Peugeot EngineRe: reynie domingo reynie domingo 01/24/20 08:59PM
  Re: Stage6 MK1 Peugeot EngineRe: scrot rash scrot rash 01/25/20 07:28AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/21/20 11:05AM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/21/20 07:03PM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/21/20 07:10PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/21/20 09:04PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/22/20 10:36AM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 01/23/20 07:45PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/23/20 08:59PM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 01/23/20 10:35PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 01/24/20 01:51PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 01/22/20 12:12AM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/22/20 02:54PM
  Re: Stage6 MK1 Peugeot EngineRe: Time Warner Time Warner 01/25/20 02:39PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/06/20 09:23PM
  Re: Stage6 MK1 Peugeot EngineRe: P D P D 02/06/20 09:36PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 02/06/20 10:20PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/06/20 10:52PM
  Re: Stage6 MK1 Peugeot EngineRe: * * * * 02/11/20 03:20AM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 02/06/20 11:37PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/10/20 10:16PM
  Re: Stage6 MK1 Peugeot EngineRe: EH FCC of the QCB EH FCC of the QCB 05/05/20 08:30AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/05/20 09:56AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/05/20 10:02AM
  Re: Stage6 MK1 Peugeot EngineRe: Ryan Graeme Ryan Graeme 05/05/20 11:57PM
  Re: Stage6 MK1 Peugeot EngineRe: Roger Suarez Roger Suarez 05/05/20 08:14PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 05/06/20 09:07AM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 05/06/20 01:42PM
  Re: Stage6 MK1 Peugeot EngineRe: Daniel '' Daniel '' 05/26/20 01:28PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 05/26/20 04:46PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 05/06/20 10:49AM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 05/06/20 01:43PM
  Re: Stage6 MK1 Peugeot EngineRe: Roger Suarez Roger Suarez 05/07/20 01:21AM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 05/19/20 08:04AM
  Re: Stage6 MK1 Peugeot EngineRe: P D P D 05/19/20 10:04AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/25/20 10:03PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/25/20 10:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/26/20 12:00PM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 05/27/20 02:26AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 05/27/20 09:36AM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 05/27/20 02:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 06/04/20 10:52AM
  Re: Stage6 MK1 Peugeot EngineRe: Dirty30 Dillon Dirty30 Dillon 06/04/20 02:09PM
  Re: Stage6 MK1 Peugeot EngineRe: Pritza R&D Pritza R&D 06/05/20 11:40AM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 06/07/20 01:25AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 06/08/20 12:35PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/15/20 03:03PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/15/20 03:04PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/15/20 03:07PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/15/20 03:50PM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/16/20 11:03PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/17/20 10:06AM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/17/20 09:21PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 07/23/20 03:51PM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/24/20 06:54PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/24/20 08:16PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 07/24/20 08:37PM
  Re: Stage6 MK1 Peugeot EngineRe: iskra chornia iskra chornia 07/25/20 11:19AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/18/20 08:15PM
  Re: Stage6 MK1 Peugeot EngineRe: Toledo Riot Toledo Riot 08/19/20 11:28AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/20/20 10:51PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/15/20 07:33PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 07/23/20 08:46PM
  Re: Stage6 MK1 Peugeot EngineRe: Michael Mike Naz Michael Mike Naz 08/18/20 10:57PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/22/20 08:35PM
  Re: Stage6 MK1 Peugeot EngineRe: Jesse Simonsen Jesse Simonsen 08/23/20 12:06AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/23/20 09:52AM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/22/20 08:37PM
  Re: Stage6 MK1 Peugeot EngineRe: Jay Rivett Jay Rivett 08/23/20 10:29AM
  Re: Stage6 MK1 Peugeot EngineRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 08/23/20 04:04PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/24/20 11:19AM
  Re: Stage6 MK1 Peugeot EngineRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 08/24/20 02:06PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 08/31/20 02:38PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 03:05PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 03:11PM
  Re: Stage6 MK1 Peugeot EngineRe: Joel P Joel P 01/05/21 08:33PM
  Re: Stage6 MK1 Peugeot EngineRe: Graham Motzing Graham Motzing 01/05/21 09:11PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 02/17/21 10:47PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/17/21 11:17PM
  Re: Stage6 MK1 Peugeot EngineRe: Tweaker trash Tweaker trash 02/17/21 11:30PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 09:26PM
  Re: Stage6 MK1 Peugeot EngineRe: Graham Motzing Graham Motzing 01/05/21 09:41PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 01/05/21 09:57PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/17/21 05:30PM
  Re: Stage6 MK1 Peugeot EngineRe: L e e L e e 02/17/21 05:37PM
  Re: Stage6 MK1 Peugeot EngineRe: Siezed Again Siezed Again 01/10/21 10:44AM
