Peugeot Variators? Which is worth the price?
Full disclosure Ive built a few fast Moby's and love the clutch'd ER3, Im not a huge fan of the clutch'd pulley's, so lets get that out of the way, with a FIXED PULLEY, what is your favorite Vario and why?
Speaking for myself, a stock 103 Vario with 3 balls, 2 star spring washers, weights either lightened or replaced with 2 m6 nuts, and lightened starter clutch shoes has been my jam, seems to be as good or better then the aftermarket varios Ive run on Moby's, WITH the ability to start the bike sans cardboard.
So are the ER3's or other aftermarket options worth it on the 103?
Re: Peugeot Variators? Which is worth the price?
Clutched Peugeot variator’s use the stock clutch so the only one worth using is t he er3, otherwise you might as well just mod the stock one.
What do you consider the advantage? The cheek angle or the east weight changes?
Mostly easy weight changes, the stock weights require complete disassembly of the clutch/vario to access.
Not sure on the cheek angles, or amount of range on stock vs Doppler
er3
I feel like the clutch pully set actually weighs more and hurts acceleration?
Clutch pulley doesn’t make it slower. Wtf are you talking about, you must not have ever ridden a bike with one? Even a very mild build with a clutch pulley will blow the doors off of most bikes acceleration wise. They come set with fairly low engagement, but seems to work well for most people unless they’re trying to slip the clutch right into the power. It’s very fun like this, but can potentially shear the crank when the variator starts working. I’ve seen it happen twice now. A Peugeot variator is not fixed to the crank very well, it’s basically held on by hopes and dreams.
> Rocco Taco Wrote:
> er3
> acceleration?
You know on my Mobys, I can normally beat people with Clutch'd Pulleys off the line, but I bet in very high end builds this scenario would flip, like high high end stuff, all my Av10's are complete rebuilds with kits
I dont mind taking them apart, but thats me, I think the cheek angle and range is the real question, which is better
Peugeot is not the same as moby. I had a middle of the road gila70/spx circuit build that would just climb the steepest hills without any hesitation up to 40mph. With the stock clutch the starter clutches hold you back a lot.
> hopes and dreams.
I’m not talking about top end, I’m talking about bottom end and how its transferred thrue the system.
Riot summed it up pretty good.
The clutch makes the pully heavier ( its the reverse idea of lightening parts for better acceleration.)
> you back a lot.
How so? And can you run the er3 with out them?
The starter clutches are awful. No matter how awesome you setup is as soon as you try to take off from a stop the rpms drop and bog you down for a second or so and then start climbing again.
I had removed the starter clutches on my 103 with an er3 and used a rope start plate on the flywheel. Acceleration improved a lot.
I was able to get my clutch engagement higher with ceramic balls in the clutch and two springs.
It was nice for about 50 miles and then the locking ring snapped. I reinforced it by adding two more posts to the fixed cheek of the er3 but it would still flex and cause the disc to start breaking tabs off after awhile.
I eventually put the starter clutches back in and after awhile the clutch would start locking up at stops every now and then and stall the bike out. And still slowly break apart the discs.
Just get a dual variator driven pulley from a Pug BBV or bb104V, the only messing around on a Pug is to shim it nice on the pedal shaft.
If you are going to run it on a Moby or Torrot, all you have to do is shim it nice - just like on a Pug. Stuff the counter spring a bit so the variation happens on the pulley set up rather than the counter spring.
One of those would be fun to play around with. From the few pictures I've seen they look like they were made well.
I have found that the Crank nut that comes in the ER3 kits is way too short. I wound up making my own.
One on the right is the kit one. On the left is a homemade one.
Here is one of the custom nuts installed on clutchless It has just the right length.
> right length.
Are those aluminum again? We gotta talk about this cheeta. We all know eventually the aluminum will just yak the threads after So many torque downs. You need to insert a steel sleeve with threads , it will last way long (edited)
Ha Ha you East coast boys always hand me a laugh.
I have never made any crank nuts out of aluminum. It's mild steel same as the one in the kit.
You think about maybe Harding it?
Jonathan Feldman /
I love tuned stock variators. The fact that they accept ER3 weights makes me believe they're the best stock variator for budget tuning. Never really had clutch sticking problems on em.
I dont really like clutch function ER3. I feel like they dont variate that much farther than stock. I used to always have clutch sticking problems with them but that was multiple years ago. Maybe I'm smart enough to figure out that issue now.
I really like clutch pulley peugeots. While I dont think they necessarily make a bike faster.. they will def RIP off the line way harder than a starter clutch style Peugeot variator. Belt alignment can be a little hit or miss and potentially more of a pain than mobyland.. theres ways to correct it when its off but its sorta stressful hahahah. Compared to moby where it's like bing bang boom done. But then again I've had clutch pulley set ups align pretty damn good right out the box. Wild stuff man.
Single speed or GTFO....I kid I kid. I love all this information for future builds.
SO Ive got some updates
I just "finished" tuning my 70cc 103, and I learned some things (my other 2 are 50cc's)
Specs
stock cases
Doppler crank
new bearings and seals
small port 46mm Airsal
carbon fiber Airsal reed block
19 PHBG
47mm LC head using thermosyphon
xk80 radiator
stock vario 2xstar washers/3balls/starter clutch shaved wayyyy down/lightened weights (weights were fixed to the vario arms)
ax32 belt
stock gearing
Le Partie CDI timed 1.1mm btdc
stock Le Partie box, no curve
Polini Utah pipe
Ill include some pictures later, but, I get what Jesse was saying about the stock clutch having some issues when introduced to real torque, when I swapped from the 15 sha to the 19phbg, it opened the bike up. Now my full jacket LC50 103 does about 47mph, but it does not have this kind of pull off the line, I def felt the starter clutch catch the bell a bit, so maybe this bike will get an ER3 just to eliminate that issue
That said the bike rips, fuck air cooled heads on French bikes, get you an LC head and never look back, compared to my 46mm Parma head, its night and day with temps, as of now the bike is done, but its pretty cold here, so maybe next season Ill have to re-jet it, and Ill be able to do a proper speed run, but Id give it 50 easy with stock gearing
Up next is my full LC 70cc 103
Texniq cases
stock crank
45.5mm Malossi LC jacket
Le Partie CDI
Ninja pipe
19 Polini CP
Athena reeds
thermosyphon cooling
Stock vario vario 2x star washers/3balls/starter clutch shaved/2x m6 nuts on each vario arm
ax32 belt
Polini spring
stock gearing
Im going to start building it this Saturday, shouldnt take to long as the case/crank is already together, if the above bike doesnt break a stock vario, I have a feeling this might (edited)
That is the worst radiator placement I have ever seen. How do you even sit on that? Are you running it closed loop and that’s just a catch for the vent? Your hoses are way too long and there’s too many bendy’s for thermo siphon to work properly.
Meh haters gonna hate, it works fine, my temps are consistently under 300 degrees, the nos bottle is a recovery bottle, fluid gets to hot, it overflows into there, cools down then is sucked back into the system, the other tube is just temporary, it was a 2 part radiator, I plan on capping it properly later. As far as sitting, it’s out of the way surprisingly, unlike on Mobys there isn’t an area to mount the radiator under the tank
TSA with ER3 w/ Doppler pulley and Tomahawk braces. 61 with Ryan on it at Buzzards rally. LC with DC conversion and bosch pump.
Looking good, have you ever ran any tests on temps, pump vs no pump?
“Haters gonna hate”. Not hating, I’ve been down this road before and know what I’m talking about. That radiator is gonna boil over and blast hot water up your ass. (edited)
This is true, it's happened to me. Relocate radiator and get yourself an overflow. Or don't, it's your bike.
No, no tests. I like the knowledge of knowing the water is moving and no guesses. We already have so many variables in mopeds, I just wanted to eliminate one.
there is an overflow to prevent the whole burning ass thing, that happens enough from my own life choices
Steam pressure will not be ok in that cansister it will pop and blow hot water all over you. I dare you to ride it 20 miles with out stop. It needs to have a controlled bleed into a sealed container or have it completely capped off with no overflow and purged of all air.
