Re: Peugeot Variators? Which is worth the price?
Toledo Riot /
SO Ive got some updates
I just "finished" tuning my 70cc 103, and I learned some things (my other 2 are 50cc's)
Specs
stock cases
Doppler crank
new bearings and seals
small port 46mm Airsal
carbon fiber Airsal reed block
19 PHBG
47mm LC head using thermosyphon
xk80 radiator
stock vario 2xstar washers/3balls/starter clutch shaved wayyyy down/lightened weights (weights were fixed to the vario arms)
ax32 belt
stock gearing
Le Partie CDI timed 1.1mm btdc
stock Le Partie box, no curve
Polini Utah pipe
Ill include some pictures later, but, I get what Jesse was saying about the stock clutch having some issues when introduced to real torque, when I swapped from the 15 sha to the 19phbg, it opened the bike up. Now my full jacket LC50 103 does about 47mph, but it does not have this kind of pull off the line, I def felt the starter clutch catch the bell a bit, so maybe this bike will get an ER3 just to eliminate that issue
That said the bike rips, fuck air cooled heads on French bikes, get you an LC head and never look back, compared to my 46mm Parma head, its night and day with temps, as of now the bike is done, but its pretty cold here, so maybe next season Ill have to re-jet it, and Ill be able to do a proper speed run, but Id give it 50 easy with stock gearing
Up next is my full LC 70cc 103
Texniq cases
stock crank
45.5mm Malossi LC jacket
Le Partie CDI
Ninja pipe
19 Polini CP
Athena reeds
thermosyphon cooling
Stock vario vario 2x star washers/3balls/starter clutch shaved/2x m6 nuts on each vario arm
ax32 belt
Polini spring
stock gearing
Im going to start building it this Saturday, shouldnt take to long as the case/crank is already together, if the above bike doesnt break a stock vario, I have a feeling this might (edited)
  Peugeot Variators? Which is worth the price?Topic by: Toledo Riot Toledo Riot 12/26/19 06:46PM
  Re: Peugeot Variators? Which is worth the price?Re: Daniel '' Daniel '' 12/26/19 10:21PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 12/27/19 08:50AM
  Re: Peugeot Variators? Which is worth the price?Re: Dirty Mike Dirty Mike 12/27/19 10:14AM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 12/27/19 03:54PM
  Re: Peugeot Variators? Which is worth the price?Re: Daniel '' Daniel '' 12/27/19 08:11PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 12/28/19 12:32AM
  Re: Peugeot Variators? Which is worth the price?Re: Jesse Simonsen Jesse Simonsen 12/28/19 01:13AM
  Re: Peugeot Variators? Which is worth the price?Re: * * * * 12/27/19 11:55AM
  Re: Peugeot Variators? Which is worth the price?Re: Daniel '' Daniel '' 12/27/19 01:07PM
  Re: Peugeot Variators? Which is worth the price?Re: * * * * 12/28/19 12:29AM
  Re: Peugeot Variators? Which is worth the price?Re: Rebel Moby Rebel Moby 12/28/19 09:51AM
  Re: Peugeot Variators? Which is worth the price?Re: Jesse Simonsen Jesse Simonsen 12/28/19 12:01PM
  Re: Peugeot Variators? Which is worth the price?Re: kim koo kim koo 03/25/20 08:52AM
  Re: Peugeot Variators? Which is worth the price?Re: cheetahchrome . cheetahchrome . 12/30/19 12:40AM
  Re: Peugeot Variators? Which is worth the price?Re: * * * * 12/30/19 01:49AM
  Re: Peugeot Variators? Which is worth the price?Re: cheetahchrome . cheetahchrome . 12/30/19 01:50PM
  Re: Peugeot Variators? Which is worth the price?Re: * * * * 12/31/19 12:43AM
  Re: Peugeot Variators? Which is worth the price?Re: Jonathan Feldman Jonathan Feldman 01/02/20 05:02PM
  Re: Peugeot Variators? Which is worth the price?Re: EH FCC of the QCB EH FCC of the QCB 01/02/20 05:05PM
  Re: Peugeot Variators? Which is worth the price?Re: Daniel '' Daniel '' 01/02/20 08:20PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/02/20 10:16PM
  Re: Peugeot Variators? Which is worth the price?Re: Gator San Juan Gator San Juan 01/03/20 08:08AM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/03/20 09:13AM
  Re: Peugeot Variators? Which is worth the price?Re: Gator San Juan Gator San Juan 01/03/20 12:20PM
  Re: Peugeot Variators? Which is worth the price?Re: Daniel '' Daniel '' 01/03/20 12:09PM
  Re: Peugeot Variators? Which is worth the price?Re: Gator San Juan Gator San Juan 01/03/20 12:18PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/03/20 02:37PM
  Re: Peugeot Variators? Which is worth the price?Re: Daniel '' Daniel '' 01/03/20 05:19PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/03/20 05:25PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/02/20 06:08PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/02/20 06:26PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/04/20 08:48PM
  Re: Peugeot Variators? Which is worth the price?Re: Daniel '' Daniel '' 01/04/20 08:57PM
  Re: Peugeot Variators? Which is worth the price?Re: L e e L e e 01/15/20 03:30PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/16/20 01:31PM
  Re: Peugeot Variators? Which is worth the price?Re: Daniel '' Daniel '' 01/16/20 03:56PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/16/20 05:40PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/20/20 09:25AM
  Re: Peugeot Variators? Which is worth the price?Re: Daniel '' Daniel '' 01/20/20 02:08PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/20/20 03:43PM
  Re: Peugeot Variators? Which is worth the price?Re: DrGeorgeTompson (Alan) DrGeorgeTompson (Alan) 01/22/20 05:18PM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/23/20 01:32PM
  Re: Peugeot Variators? Which is worth the price?Re: Time Warner Time Warner 01/25/20 01:09AM
  Re: Peugeot Variators? Which is worth the price?Re: Time Warner Time Warner 01/25/20 01:28AM
  Re: Peugeot Variators? Which is worth the price?Re: Daniel '' Daniel '' 01/25/20 05:49AM
  Re: Peugeot Variators? Which is worth the price?Re: Time Warner Time Warner 01/25/20 01:29AM
  Re: Peugeot Variators? Which is worth the price?Re: Toledo Riot Toledo Riot 01/25/20 07:16PM
  Re: Peugeot Variators? Which is worth the price?Re: Graham Motzing Graham Motzing 03/25/20 10:12AM
  Re: Peugeot Variators? Which is worth the price?Re: Time Warner Time Warner 01/25/20 01:55PM
