Hobbit Carb Placement and Options
Hey chumps, it's been a while.
I've been riding around a Hobbit with a 19mm PHBG hanging off the side. Works okay. No reserve on the petcock though.
I want that super-stock Hobbit look. All the panels on, etc. I went for the Malossi intake and a 17mm PHBG. I got it all installed and hit some issues.
* How the heck am i supposed to run the throttle cable?
* Should I use that Malossi short top thing?
* Cut a channel in the frame and weld a brace in?
* Give up?
Re: Hobbit Carb Placement and Options
πΏπ‘–π‘˜π‘Ž-πΏπ‘œπ‘‘π‘Žπ‘ π‘Žπ‘’π‘Ÿ π‘€π‘’π‘”π‘Žπ‘π‘’π‘  πŸ¦– /
Whaddup CJ :)
Fuctifiknow but heyyah
Ohh, cut out the air box top. :P (edited)
Don't use the bendy on the throttle cable, use the flat plastic piece. I ran a 19mm phbg with the malossi intake in a stock position for a while before using some radiator hose to sidemount it.
YOUR THR CHUMP
Scooter: What's good!!!!
JBot: Don't chump-a-tize me bro!!!!
Nick: The flat top has scary reviews. How has it worked out for you?
« Go to Topics β€” end of thread
