> jordan * Wrote:
> What're you thinking for belt with the overrange? Treats says stock
> dayco 7188 is 596mm long. I found this one for honda aero 50 that's like
> 634mm, and there's some other ones in a similar range. Pedal derbi motor
> belt is like 628, that'd probably be a good start too.
> https://www.partsforscooters.com/106-134-Bando-CVT-Belt-634-15.5-29
> It'd just be finding that balance of taking advantage of bigger rear
> while still getting the variator to close fully. I was looking around
> and on the motomatic bikes it looks like they're rocking the scooter
> vario that fits, but I also saw a few pics where it looks like they are
> running the big malossi variotop from french bikes. I haven't had my
> hands on much french stuff, but i think ya'd needa get that spline in
> there for derbi crank, maybe cut that out from old fixed cheek and weld
> it in to the french one to make it fit? Idk
I believe youβre talking about welding the splined shaft off one crank and onto another crank web to fit?
Or rear output to fit larger pulley?
