Insane ZA50 gearing
Wesley Ambrosini /
TCCD 50cc no transfer porting
Hi comp head
Techno circuit pipe
15 Bing
Had 18x37 on it and it had insane low end (for a moped)
Grinded and slapped a 20 up front, still has great bottom end and actually pulls it.
Is there an end to this madness?
Will it shorten clutch life to have this tall of gearing?
If it takes off it's good right?
Re: Insane ZA50 gearing
Overpriced Parts /
I run 20 x36 on mild kitted bikes and 21-22x35 on hi powered kitted bikes like Gila Athena and polini reed kits, stock clutches are asbestos lined and last forever/very long if they don’t become delaminated, (aftermarket clutches do not last like stock)
So run synthetic motor oil 5w20-30 not type F oil fluid, make sure you have brand new pucks/shift dampeners and flip second gear clutch, if stock crank run good synthetic 2t oil and don’t go more than 50 to 1
Wesley Ambrosini /
Thanks boss
I'm gonna throw some 5w30 in it tomorrow and check it out
Yup, trust the roffman, 5w-20 is the way to go on puchs.
Wesley Ambrosini /
Started running Mobil 1 synthetic 5w-20
Honestly the shift RPM was very similar maybe 200 rpm higher, but the shift is much more controllable. Also it the shifts stay consistent as the motor warms up
Honestly the powerband is so shit after the shift that I went back to a 18 in the front, ordered a 19
> Hi comp head
> Techno circuit pipe
> 15 Bing
> actually pulls it.
Did you go any faster?
I'm running 21/37 in my Polini za50, no issues so far and I'm running a stock crank.
20x40 on my Magnum MK....it eats hills for breakfast and is hella fast at that. I did notice a difference when I switched from an 18t to 20t. Stock crank...running type f still :)
Wesley Ambrosini /
> > Hi comp head
> > Techno circuit pipe
> > 15 Bing
> > actually pulls it.
Top speed was faster, just took all day to get there
I am rebuilding a MAGNUM II and have been reading your write up on using synthetic motor oil in yours. Did you use regular Mobil 1 or the Motorcycle Mobil 1 that is made for wet clutches? Thanks for your time.
Wesley Ambrosini /
regular ass car oil 5w-30 synthetic
10w-30 seemed to put the shift point too high, but it my be on my head
I think Rodney ran 22x24 gearing on his 74 mph speed run
Kevin Bishop /
The hard part is finding a snowflake sprocket
It was something close to that so I thought my ZA could pull 22x36.......it could not
Wesley Ambrosini /
Just kitted up to 70cc, my za now easily pulls a 21x37
No replacement for displacement
It all depends what you consider pulling....
Dirty30 Dillon /
My ZA50 was just a simple ported kstar/vm20/gigantour chamber, and it pulled very well with 22/36, rocked dubs uphill steadily and would cruise around 50 with 300+ pounds of combined human meat on top.
Man I I’d not get that. I have basically the same setup but a 21phbg and mini rotor with a 70cc Athena PP kit and it crushes 18x36 but I go bigger and fucking Tomos beat me off the line......I can’t live like that.
Kevin Bishop /
I don’t know how you can get a 22 on a Za I barely got a 21 on mine. Grinding the case and there is barely an 1/8” space left.
Za clutches are weird man, They’re all so different feeling! Year to year, model to model it doesn’t seem to matter, no two are alike. You can blow through the case it’s no big deal, just gotta keep that chain clean. I’ve seen tomos sprockets on za before, Idk how it performed though.
Wesley Ambrosini /
Actually accelerating after the shift into second haha
Dirty30 Dillon /
> though.
This is the biggest thing. ZA's seem to have so many minute manufacturing variations that account for every one being different depending on the model and year bike it came on.
