What head? 50cc treats kit
Wesley Ambrosini /
Za50
Tecno circuit
Treats 50cc for the people kit
Had a hi hi head on it, was getting badass bottom end but it didn't want to pull after the shift
Just kinda hung on at 5500k maybe 6000k
Slapped a stock head on there marginal bottom end loss but nice top end gains.
Getting mid to high 30s now
Any better heads out there for this kit?
I have a hi torque magnum head, but I gotta shave the fins to get it to fit with the circuit pipe..
Is it just time to get a big boy 70cc kit?
Re: What head? 50cc treats kit
> Wesley Ambrosini Wrote:
> Za50
> Tecno circuit
> gains.
Ditch that junk pipe and you'll do better, but a stock head should be fine on there
Wesley Ambrosini /
> > Za50
> > Tecno circuit
> want
> end
> > gains.
> to
> fine on there
Doesn't seem to be a lot of options for pipes that allow you to keep the pedals, aren't made for super high revs, and are under $200
> > > Za50
> > > Tecno circuit
> > want
> > end
> > > gains.
> > to
> > fine on there
Bend your pedal arm, or get a Magnum pedal shaft.
gearing?
Tecno pipe is good enough, it has a power band, isn’t too loud and clears pedals. Maybe check your timing? Points gap on a za50 is .45-.5mm, timing is between 1.1-1.5mm max advance.
Wesley Ambrosini /
Gearing is at 18-37. It can barely pull 20-37 after the shift
I haven't checked to see if the gap drifted in the past few months, timing is right at 16mm (on the flywheel) checked with a light
Mid high thirties on a 50cc is sick for me I just want more balls in the mids
16* is not the measurement of mm I was referring to. That’s pretty retarded timing for a low rev 50cc set up. I would try around 20*
Wesley Ambrosini /
I bumped up (down?) to 20* still cruising pretty cool at 250*f with an 8 plug
Way cooler than the hi hi head
