Am I running out of air?
Treats 70cc cylinder kit
Treats stuffed crank
Case matched
15mm bing clone 2.15 atomizer with #1 grandpa intake don’t remember the jet.
Treats hi compression head
PROMA circuit pipe
My problem is with four stroking at top end, I’ve gone up and down with jetting then went to the 2.15 atomizer that did help but I’ve still got the problem. So I’m wondering if I need a bigger carb-intake but here’s the issue is it will be going on a pinto and the frame might be in the way of the carb. So what do you think, More carb or ?. thanks for any and all help.
Re: Am I running out of air?
Dirty30 Dillon /
I had a similar issue, ended up being a bad trans seal/case seal that was allowing it to suck in ATF at higher rpms. This made is seem rich no matter my jetting, as the oil would foul it once it was pumping enough to suck it up from the trans res
carb size is fine, u need smaller jets, but... could be choke stuck on or float not closing off fuel inlet as well, or a super restrictive air filter.
Maybe your slide isn't opening all the way. It happens
Samzies.....is it smoking more than normal? Mine had a nice constant white smoke.....
Jbot the slider is opening all the way. It did have a problem with a vacuum leak that I fixed but it might still have one, I'll try a propane enrichment test.
♣Slew Foot♣ /
R U. turnin blue? Feelin woozy dial 911...
Aaron Ward /
CDI or points? I had a treats CDI that would stumble in the high high RPMs. Felt very 4strokey.
♣Slew Foot♣ /
G flow pattern turbulence slider cut out....
