Peugeot polini spring setup fit with stock pipe?
Wanting to ditch stock spring. The crossbar where the spring mounts on the subframe of my 103 is welded on not removable. If I remove the engine i struggle so damn much with reinstalling it with the spring fighting me and getting those little spacers on between the engine mount and subframe.
Re: Peugeot polini spring setup fit with stock pipe?
Yes. The polini spring was meant to be used with the stock spring.
Did you mean stock pipe?
No. You can’t remove your stock spring and substitute the polini spring. It is weaker than the stock spring and will not work unless it’s used in conjunction with the stock spring.
Cool thanks man thought it was a replacement for the stock springy. My first Peugeot just started messing with the variator reading up on some posts trying to avoid classic pug problems
