Re: Epic Vespa Thread
Yeah, I did refill the transmission. I'm going to have to take it all apart and see what happened.
It turns out the clutch nut rubbed against the face of the transmission and worked its way free. The clutch exploded when I pulled the bell off. Also the threads on the clutch seem stripped. Transmission seems salvageable, but I think the clutch is toast.
Did something similar. It milled the tranny case to unuseable by mere.
mortals.
I'm so bummed I've been working on my hobbits. Vespas are neglected. I could make a nice video of a circumnavigation of davis but might have incriminating footage of use of greenbelt paths.
What 10 pin con rod bearings are people using? Just curious...
I've not tried that. Are you converting a stock conrod to needle?
It is a stock needle 10 pin. Just curious on what size people are using.
Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F /
I’m using an 11 pin
Dirty30 Dillon /
> using.
I'm fairly certain I'm running either the Polini or doppler 10x14x13 in two of my bikes, but hinestly it's been so long. Didn't get a shop hour in the week, but I'll yank the OI motor I have off the shelf and mic out the specs.
Ain't she a beaut? I swapped transmissions and clutches and just sent it.
.I've got both. A couple are 12 pin. I think this grande with the 43 malossi, kinetic cdi with rectified and regulated from a set up.
I forgot to get better pictures before I put the bike away but that's for the rectifier and the regulator are located seems to work pretty good I get really clean 12 volt LED power now
I'm not bored with it yet.
I love the 30 pack rack.
I’ve been playing with my grande. I remade the fixed variator cheek that spaced it out to allow the belt to sit on the shaft. It really helped with off the line power. I tried the jbot belt dressing to help with my floppy belt. It helped I think there may still be a high spot. At wot it feels like it’s starving for fuel. But the next jet up it 4 strokes throughout the throttle range. I need to pull the carb apart to see if that filter at the fuel inlet is clogged, the tank was pretty crusty when I got the frame. But the bike it ripping even though I can’t get a wot run.
Damn Joe that is a nice belt Jig!
Thanks Eric. Im thinking there is probably still a low spot, I pulled it though until I didn’t have anymore resistance. I need to move in one of the blocks and dress it some more. It’s kinda hard to measure since the belts beat up from flapping against the subframe.
New seat on the Big Red Bravo!
Now I see the splendid bravo seat... Wow you can stretch out.
