Re: Crazy Custom Frame Hobbit
Colin Ratcliff /
Alright all, I'm at a complete loss and need your advice. I will test anything you tell me to test and try anything at all.
I'm completely at a loss - I feel like I have tried everything and I am usually able to figure out what's up with the running issues
It idles okay, and starts right up, but it won't pull with any power at all. Current setup is:
Malossi Liquid Cooled Kit
HPI Ignition
TJT Variator
Red Springs
VM20 with 180 jet
One way bearing
BR7HS plug
I have:
-jetted everywhere from 110-210, seems to run a little better at 110, but still can't rev very high or with any power
-changed to blue springs - it will then grab, but won't variate, and I can stop it from spinning by hand (engine will still run, clutch just disconnects)
-done a leakdown test - almost no loss at all (still in "set" not even at 20% loss in green)
-cleaned the carbs and verified that the floats aren't sticking
-plug seems pretty clean. Not super sooty or anything
A couple things I noticed and checked:
-it would lose power after a few seconds at WOT. I switched out the fuel switch for a different one and that resolved the issue.
-it would slowly drip fuel at the overflow for the carb, and also seemed to run better when I turned the fuel off for about 10 seconds and kept revving it. This is why I checked the float. Fuel drip seems to be gone after checking the float but the other issues are still present.
-sometimes it will die after a long period of WOT. Haven't figured out why.
Video of it running with a 180 jet here:
https://photos.app.goo.gl/GujtqaFuN3EwN7Tp7
  Crazy Custom Frame HobbitTopic by: Colin Ratcliff Colin Ratcliff 02/15/20 01:13PM
  Re: Crazy Custom Frame HobbitRe: Aaron Blair Aaron Blair 02/15/20 01:24PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 01:33PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/15/20 02:27PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 02:57PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 02/16/20 12:27AM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/15/20 02:36PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 02:55PM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/15/20 03:01PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 08:32PM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/15/20 03:06PM
  Re: Crazy Custom Frame HobbitRe: Dickie Thompson Dickie Thompson 02/15/20 04:31PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 08:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 11:19PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/15/20 11:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 11:38PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/16/20 01:47AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/16/20 01:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/16/20 02:23PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/16/20 02:25PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/16/20 02:29PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/16/20 03:50PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/16/20 03:54PM
  Re: Crazy Custom Frame HobbitRe: Russell Huddy Russell Huddy 02/16/20 11:57AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/16/20 01:46PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/16/20 01:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/16/20 02:31PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/16/20 02:39PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/16/20 03:28PM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/20/20 04:30PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 02/20/20 04:56PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/20/20 11:48PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/20/20 11:57PM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/21/20 01:08AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/21/20 12:42PM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/21/20 03:38PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/21/20 01:43AM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/21/20 03:08PM
  Re: Crazy Custom Frame HobbitRe: Born to be WillD Born to be WillD 02/24/20 01:06PM
  Re: Crazy Custom Frame HobbitRe: Dickie Thompson Dickie Thompson 02/16/20 08:57PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/16/20 10:47PM
  Re: Crazy Custom Frame HobbitRe: viv v viv v 02/16/20 11:09PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/17/20 11:03AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/17/20 11:49AM
  Re: Crazy Custom Frame HobbitRe: Jake P Jake P 02/17/20 03:28PM
  Re: Crazy Custom Frame HobbitRe: Duane {SpicyBoys} Duane {SpicyBoys} 11/21/20 06:56PM
  Re: Crazy Custom Frame HobbitRe: Alexis Wilber Alexis Wilber 02/20/20 04:17PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/24/20 01:21PM
  Re: Crazy Custom Frame HobbitRe: jumpsuit steve jumpsuit steve 02/26/20 10:35PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/26/20 10:45PM
  Re: Crazy Custom Frame HobbitRe: jumpsuit steve jumpsuit steve 02/27/20 09:46AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/27/20 11:14AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 02/27/20 11:44AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/27/20 01:00PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 02/27/20 01:34PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/27/20 02:03PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/29/20 12:31PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/21/20 02:15AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/25/20 02:19PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/25/20 10:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/25/20 02:22PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 04/20/20 11:57PM
  Re: Crazy Custom Frame HobbitRe: Emil Kniemel Emil Kniemel 08/04/20 02:21PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 05/10/20 07:55PM
  Re: Crazy Custom Frame HobbitRe: P D P D 05/11/20 09:41AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 05/11/20 11:45AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 05/11/20 12:15PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/20/20 01:36PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 07/20/20 01:57PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/20/20 02:27PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 07/20/20 02:53PM
  Re: Crazy Custom Frame HobbitRe: Emil Kniemel Emil Kniemel 07/20/20 03:51PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/20/20 04:10PM
  Re: Crazy Custom Frame HobbitRe: Emil Kniemel Emil Kniemel 07/21/20 01:16PM
  Re: Crazy Custom Frame HobbitRe: Born to be WillD Born to be WillD 07/21/20 05:02PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/21/20 05:48PM
  Re: Crazy Custom Frame HobbitRe: Emil Kniemel Emil Kniemel 07/21/20 05:53PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 07/20/20 07:26PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/20/20 09:19PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 07/20/20 11:52PM
  Re: Crazy Custom Frame HobbitRe: P D P D 07/21/20 10:13AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/21/20 03:31PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/21/20 03:34PM
  Re: Crazy Custom Frame HobbitRe: Satan 666 Satan 666 07/21/20 10:13PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/22/20 12:44PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/22/20 01:34PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/22/20 03:45PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/23/20 02:12AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 07/23/20 01:19PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/23/20 01:34PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/27/20 04:06PM
  Re: Crazy Custom Frame HobbitRe: Jesse Stephenson Jesse Stephenson 08/04/20 05:05AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 08/04/20 01:53PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 08/04/20 02:13PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 08/04/20 02:19PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 08/04/20 02:29PM
  Re: Crazy Custom Frame HobbitRe: P D P D 08/04/20 02:38PM
  Re: Crazy Custom Frame HobbitRe: Ryan Graeme Ryan Graeme 08/04/20 04:09PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 08/04/20 04:51PM
  Re: Crazy Custom Frame HobbitRe: Aaron Blair Aaron Blair 08/06/20 06:01AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 08/06/20 11:20AM
  Re: Crazy Custom Frame HobbitRe: alex . alex . 07/27/20 04:16PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 08/04/20 04:55PM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 08/05/20 11:32PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 08/06/20 12:34PM
  Re: Crazy Custom Frame HobbitRe: Aaron Blair Aaron Blair 08/06/20 06:19AM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 08/06/20 12:18PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 08/10/20 12:46PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/20/20 07:26PM
  Re: Crazy Custom Frame HobbitRe: Dickie Thompson Dickie Thompson 09/21/20 10:43AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/21/20 01:21PM
  Re: Crazy Custom Frame HobbitRe: Emil Kniemel Emil Kniemel 09/21/20 01:50PM
  Re: Crazy Custom Frame HobbitRe: Aaron Goldman Aaron Goldman 09/23/20 08:48AM
  Re: Crazy Custom Frame HobbitRe: TOP GUN™ ANDY ⚔ (LSLB) ⚔ TOP GUN™ ANDY ⚔ (LSLB) ⚔ 08/20/20 09:32AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/22/20 11:43PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 09/25/20 08:03AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/22/20 11:51PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/22/20 11:56PM
  Re: Crazy Custom Frame HobbitRe: Papa _ Papa _ 09/23/20 03:02AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/23/20 12:56PM
  Re: Crazy Custom Frame HobbitRe: Todd S Todd S 09/23/20 11:35PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/23/20 11:50PM
  Re: Crazy Custom Frame HobbitRe: Aaron Goldman Aaron Goldman 09/24/20 09:40AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 09/24/20 01:23AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/24/20 01:27AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 09/24/20 01:50AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 09/25/20 04:04AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/25/20 11:30AM
  Re: Crazy Custom Frame HobbitRe: Aaron Blair Aaron Blair 09/29/20 07:01AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 09/29/20 11:46AM
  Re: Crazy Custom Frame HobbitRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 09/25/20 09:50AM
  Re: Crazy Custom Frame HobbitRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 09/25/20 09:53AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/25/20 11:28AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 09/25/20 12:20PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/25/20 01:18PM
  Re: Crazy Custom Frame HobbitRe: Aaron Goldman Aaron Goldman 09/25/20 01:59PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/25/20 02:05PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 09/25/20 02:13PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/25/20 03:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/30/20 02:09PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/30/20 02:11PM
  Re: Crazy Custom Frame HobbitRe: Aaron Blair Aaron Blair 09/30/20 10:21PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/28/20 10:31PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/28/20 10:34PM
  Re: Crazy Custom Frame HobbitRe: Graham Motzing Graham Motzing 09/29/20 08:40AM
  Re: Crazy Custom Frame HobbitRe: Graham Motzing Graham Motzing 09/29/20 08:41AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/30/20 02:31PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/30/20 03:07PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/30/20 03:10PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/30/20 03:16PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/01/20 02:52PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/01/20 03:15PM
  Re: Crazy Custom Frame HobbitRe: Dickie Thompson Dickie Thompson 10/01/20 09:23PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/01/20 11:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/25/20 03:39PM
  Re: Crazy Custom Frame HobbitRe: Ryan Graeme Ryan Graeme 10/25/20 04:42PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 10/25/20 07:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/28/20 12:06PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 10/28/20 01:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/26/20 01:41PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 10/26/20 03:49PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 10/27/20 02:44AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 10/27/20 09:11AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/26/20 01:54PM
  Re: Crazy Custom Frame HobbitRe: Dickie Thompson Dickie Thompson 10/26/20 01:55PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/26/20 02:10PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/26/20 04:07PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/26/20 05:20PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/27/20 03:39PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 10/27/20 03:58PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/27/20 04:02PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 10/27/20 04:52PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/27/20 04:05PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/27/20 05:39PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/28/20 12:55PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/28/20 01:25PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/28/20 01:27PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/28/20 01:41PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/28/20 01:49PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/28/20 01:54PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/28/20 03:31PM
  Re: Crazy Custom Frame HobbitRe: Bo Valencia Bo Valencia 02/17/21 12:51AM
  Re: Crazy Custom Frame HobbitRe: Bo Valencia Bo Valencia 02/17/21 12:54AM
  Re: Crazy Custom Frame HobbitRe: Wolf Wizard Wolf Wizard 10/28/20 06:32PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 10/29/20 10:00AM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 10/29/20 10:51PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/30/20 11:33AM
  Re: Crazy Custom Frame HobbitRe: * wormdirt * * wormdirt * 11/05/20 02:16PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 11/06/20 11:06PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 11/12/20 05:57AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 11/12/20 09:06AM
  Re: Crazy Custom Frame HobbitRe: Graham Motzing Graham Motzing 11/12/20 11:21AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/12/20 11:47AM
  Re: Crazy Custom Frame HobbitRe: Wolf Wizard Wolf Wizard 10/28/20 07:08PM
  Re: Crazy Custom Frame HobbitRe: Graham Motzing Graham Motzing 10/28/20 07:35PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/28/20 09:03PM
  Re: Crazy Custom Frame HobbitRe: P D P D 10/28/20 09:25PM
  Re: Crazy Custom Frame HobbitRe: Sander Mulder Sander Mulder 10/29/20 09:31AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/29/20 01:47PM
  Re: Crazy Custom Frame HobbitRe: Sander Mulder Sander Mulder 10/29/20 05:33PM
  Re: Crazy Custom Frame HobbitRe: Sander Mulder Sander Mulder 10/29/20 05:57PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/29/20 08:14PM
  Re: Crazy Custom Frame HobbitRe: L e e L e e 10/30/20 11:05AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/30/20 03:54PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/17/21 12:18AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/03/20 01:34AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/03/20 01:35AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/03/20 03:26AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/05/20 01:23PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 11/05/20 01:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/05/20 03:47PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/06/20 01:04PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 11/06/20 01:16PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/06/20 01:22PM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 11/06/20 02:17PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/06/20 02:29PM
  Re: Crazy Custom Frame HobbitRe: Ryan Graeme Ryan Graeme 11/13/20 10:41AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/13/20 11:41AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 11/13/20 02:11PM
  Re: Crazy Custom Frame HobbitRe: Graham Motzing Graham Motzing 11/13/20 02:14PM
  Re: Crazy Custom Frame HobbitRe: Satan 666 Satan 666 11/14/20 10:26AM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 11/14/20 11:03AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/16/20 04:08PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 11/16/20 05:54PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/16/20 04:09PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 11/17/20 12:12PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/17/20 01:17PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/21/20 01:08PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/21/20 08:53PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/22/20 01:39PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 11/24/20 10:13AM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 11/21/20 04:15PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 11/21/20 05:08PM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 11/21/20 05:42PM
  Re: Crazy Custom Frame HobbitRe: Anthony Moody Anthony Moody 11/23/20 10:45PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 11/24/20 12:11AM
  Re: Crazy Custom Frame HobbitRe: P D P D 11/24/20 09:06AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 11/24/20 12:02PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/23/20 12:44PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/23/20 11:21PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/23/20 11:25PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/24/20 02:30PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 12/07/20 12:36PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 12/07/20 01:04PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 12/07/20 01:16PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 12/07/20 03:35PM
  Re: Crazy Custom Frame HobbitRe: P D P D 12/07/20 03:44PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 12/07/20 07:10PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 12/09/20 05:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 12/15/20 02:34PM
  Re: Crazy Custom Frame HobbitRe: Aaron Goldman Aaron Goldman 12/18/20 08:53PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 12/19/20 11:53AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 12/19/20 12:12PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 12/20/20 03:12PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 12/20/20 05:44PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 12/22/20 02:56PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 12/22/20 10:44PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 12/24/20 12:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/04/21 05:43PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/05/21 07:35PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/05/21 07:47PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/05/21 07:52PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/05/21 09:24PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/05/21 07:53PM
  Re: Crazy Custom Frame HobbitRe: Joe Schuitema Joe Schuitema 01/05/21 09:45PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/06/21 06:21PM
  Re: Crazy Custom Frame HobbitRe: Joe Schuitema Joe Schuitema 01/06/21 08:15PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/06/21 09:02PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/07/21 12:08AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/07/21 01:25AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/10/21 01:34PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 01/10/21 04:15PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/10/21 07:53PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/10/21 05:39PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/10/21 05:46PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/10/21 05:48PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/10/21 07:38PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/10/21 09:54PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/10/21 10:05PM
  Re: Crazy Custom Frame HobbitRe: Joe Schuitema Joe Schuitema 01/10/21 10:10PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/10/21 10:53PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/11/21 12:32AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/11/21 12:59AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/11/21 09:45AM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 01/13/21 07:50AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/13/21 12:20PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/11/21 06:02PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/12/21 12:52PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/12/21 01:20PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/12/21 02:54PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/12/21 02:56PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/13/21 03:10AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/13/21 12:10PM
  Re: Crazy Custom Frame HobbitRe: reynie domingo reynie domingo 01/13/21 02:55PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/14/21 12:40AM
  Re: Crazy Custom Frame HobbitRe: reynie domingo reynie domingo 01/14/21 07:13PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/14/21 07:56PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/14/21 10:33PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 01/15/21 10:02AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/15/21 12:24PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/15/21 12:21PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/15/21 12:43PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/15/21 12:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/15/21 12:31PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/15/21 12:46PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 01/15/21 01:06PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/15/21 01:30PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/16/21 06:43PM
  Re: Crazy Custom Frame HobbitRe: * wormdirt * * wormdirt * 01/16/21 09:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/17/21 12:52PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/17/21 12:23AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/18/21 10:49PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/20/21 03:33PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/22/21 12:01AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/20/21 08:39PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/20/21 09:11PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/20/21 10:43PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/21/21 12:47AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/21/21 12:48AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/21/21 01:09AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/21/21 11:59AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/21/21 07:43PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/21/21 08:09PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/22/21 12:07AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 11:46AM
  Re: Crazy Custom Frame HobbitRe: P D P D 01/22/21 12:01PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/22/21 12:35PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 01:37PM
  Re: Crazy Custom Frame HobbitRe: P D P D 01/22/21 02:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 04:47PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/22/21 05:21PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/22/21 05:32PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/22/21 09:39PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/22/21 10:02PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/23/21 12:59AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/23/21 12:36PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 01/23/21 05:04PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/23/21 05:10PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 01/22/21 05:02PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 05:45PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/22/21 05:52PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 06:28PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/22/21 07:13PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 07:51PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/23/21 11:23PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/24/21 01:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/24/21 12:00AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/24/21 12:48AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/24/21 11:40AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/24/21 01:23PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/24/21 04:53PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/24/21 05:30PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/24/21 03:03PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/24/21 03:48PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/24/21 07:47PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/25/21 02:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/25/21 03:16PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/26/21 01:34AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/25/21 03:32PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/25/21 03:36PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/26/21 11:07AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/29/21 08:48PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/29/21 10:20PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/29/21 08:52PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/29/21 09:08PM
  Re: Crazy Custom Frame HobbitRe: Joe Schuitema Joe Schuitema 01/29/21 09:14PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/29/21 11:16PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/29/21 11:55PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 10:21AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 11:18AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 11:56AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 12:00PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/30/21 12:38PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/30/21 01:34PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 02:07PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 05:38PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 05:49PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 05:57PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 01/30/21 07:06PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 12:41PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/30/21 12:50PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 02:07PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 05:54PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 06:51PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 06:53PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 08:16PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 08:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 07:01PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 07:16PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 07:23PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 01/30/21 08:32PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 09:51PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 11:16PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 11:32PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 11:32PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/31/21 02:44AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 03:54AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/31/21 12:11PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 02/01/21 11:30AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/31/21 12:48PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 11:36PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/31/21 12:17AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 12:26AM
  Re: Crazy Custom Frame HobbitRe: Joe Schuitema Joe Schuitema 01/30/21 11:39PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/31/21 02:06AM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 01/31/21 11:15AM
  Re: Crazy Custom Frame HobbitRe: Papa _ Papa _ 01/31/21 02:22PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 02:35PM
  Re: Crazy Custom Frame HobbitRe: P D P D 01/31/21 05:04PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 05:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/31/21 07:53PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 08:20PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/31/21 09:11PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/31/21 10:05PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 10:25PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 01:18AM
  Re: Crazy Custom Frame HobbitRe: * wormdirt * * wormdirt * 02/01/21 02:02AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 11:14AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/01/21 10:50AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:11AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:33AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/01/21 11:54AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 01:48PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 12:15PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 01:26PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 01:50PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 01:59PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:06PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:08PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 02:46PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 02:12PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:14PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:20PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:13PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 02/01/21 02:21PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 02:32PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:55PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 03:20PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/01/21 03:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 04:11PM
  Re: Crazy Custom Frame HobbitRe: P D P D 02/01/21 04:22PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 07:17PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 02/01/21 09:40PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 08:09PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 09:24PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 09:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 08:12PM
  Re: Crazy Custom Frame HobbitRe: P D P D 02/01/21 08:42PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 10:56PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 11:04PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 11:16PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:11PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:37PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 11:42PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:38PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 11:50PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/02/21 12:03AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:57PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/02/21 12:15AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 12:01AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 12:06AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/02/21 12:11AM
  Re: Crazy Custom Frame HobbitRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 02/02/21 10:31AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/02/21 12:42PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 11:36AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 02/02/21 11:49AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 11:57AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 12:08PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 03:55PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/02/21 09:28PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/02/21 10:48PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/02/21 11:49PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 02/03/21 11:14AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/03/21 12:21PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/03/21 12:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/03/21 02:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/05/21 05:24PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/05/21 05:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/05/21 05:50PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/15/21 09:57PM
  Re: Crazy Custom Frame HobbitRe: Rubble Raiser Rubble Raiser 02/17/21 02:05AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/20/21 07:37PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/20/21 09:43PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/20/21 11:32PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/22/21 11:56AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/22/21 12:07PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/22/21 03:58PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/22/21 10:15PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/22/21 11:47PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/23/21 01:12AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/23/21 10:24PM
  Re: Crazy Custom Frame HobbitRe: Jeremy Freeze Jeremy Freeze 02/24/21 12:01AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/24/21 11:18AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/24/21 11:20AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/24/21 01:16PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/24/21 01:17PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/24/21 03:50PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 02/24/21 04:04PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/24/21 05:03PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/24/21 07:30PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/24/21 07:58PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/24/21 01:31PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/24/21 10:01PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 02/25/21 07:33AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/25/21 10:56AM
  Re: Crazy Custom Frame HobbitRe: Jeremy Freeze Jeremy Freeze 02/25/21 11:56AM
  Re: Crazy Custom Frame HobbitRe: Papa _ Papa _ 02/25/21 01:07PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 02/26/21 07:33AM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 02/26/21 07:42AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/26/21 02:51PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/01/21 11:18PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/01/21 11:27PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/02/21 01:04AM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 03/02/21 10:44AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 03/02/21 11:15AM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/02/21 11:32AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 03/02/21 09:38AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/02/21 11:56AM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/02/21 12:07PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/02/21 12:17PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/02/21 12:30PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/02/21 12:40PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 03/02/21 12:55PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/02/21 01:10PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/02/21 01:22PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 03/02/21 01:50PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/02/21 01:02PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/01/21 11:34PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/02/21 11:09AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/02/21 12:58PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/02/21 05:06PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/02/21 05:43PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/02/21 07:26PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/02/21 10:17PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 12:17PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:30PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/03/21 12:31PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:36PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/03/21 12:37PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/03/21 12:40PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:39PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 12:37PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:41PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 12:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:45PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 12:49PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:56PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/03/21 01:14PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 01:36PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 01:37PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/03/21 03:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 05:26PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 06:23PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/03/21 07:30PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/03/21 07:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 08:24PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/04/21 11:02AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 03/04/21 11:05AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/04/21 11:51AM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 03/04/21 02:29PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/04/21 11:07AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 03/04/21 11:18AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/04/21 11:33AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 03/04/21 11:50AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/04/21 04:19PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 03/04/21 05:09PM
  Re: Crazy Custom Frame HobbitRe: Mike Boyd Mike Boyd 03/09/21 02:36PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/04/21 05:37PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 03/04/21 10:54PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/09/21 11:36AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/10/21 04:40PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/22/21 07:06PM
  Re: Crazy Custom Frame HobbitRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/23/21 02:18PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 04/01/21 01:37PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 04/01/21 06:04PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 04/02/21 02:08PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 04/09/21 06:13PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 04/09/21 06:18PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 04/09/21 06:20PM
