Re: Crazy Custom Frame Hobbit
Colin Ratcliff /
Downdraft is a cool idea, but I think with the polini I can get it a bit shorter.
I'm also definitely planning to change the engine angle in the future.
Updates! With all the snow here I kinda put off working on it for a couple weeks, but got at it again today:
1) upped the pilot jet for the 52 and it seems super happy, though for some reason I can't turn the idle down enough to kill it - I thought there was a vacuum leak somewhere but can't find one. I don't THINK the angle of the carb would cause this, and when I take it off and angle it to the same angle as it's mounted, there's no fuel leaking.
2) there's something off with the wiring, which is causing it to not get nearly enough power. The headlight is suuuuuper dim, and the water pump won't work when the headlight is on. This is with the trailtech reg/rec. I'm wondering if it's only putting out 6v or something.
3) I'm pretty sure there's a head gasket leak into the water jacket - when I disconnected the water pump and revved it up, it looks like it's bubbling like crazy in the radiator. I'm not 100% sure that's not just a result of all the vibration.
4) I tried torqueing down the head further, set my torque wrench to 8.5, and snapped one of the studs. Thankfully I use cylinder studs instead of bolts, and it snapped at the head, so I just have to wait for new ones to come in from treats, and it didn't damage the case or anything.
SO, I ordered new studs from Treats, also ordered new gaskets, and once those come in I'm gonna try to figure out what's wrong with the wiring, and tune the jets.
Also gonna hit up the auto parts store and get some bent intake hose to mount the carb at a more level angle (right now it's at like 30 degrees or more)
  Crazy Custom Frame HobbitTopic by: Colin Ratcliff Colin Ratcliff 02/15/20 01:13PM
  Re: Crazy Custom Frame HobbitRe: Aaron Blair Aaron Blair 02/15/20 01:24PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 01:33PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/15/20 02:27PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 02:57PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 02/16/20 12:27AM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/15/20 02:36PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 02:55PM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/15/20 03:01PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 08:32PM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/15/20 03:06PM
  Re: Crazy Custom Frame HobbitRe: Dickie Thompson Dickie Thompson 02/15/20 04:31PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 08:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 11:19PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/15/20 11:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/15/20 11:38PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/16/20 01:47AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/16/20 01:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/16/20 02:23PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/16/20 02:25PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/16/20 02:29PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/16/20 03:50PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/16/20 03:54PM
  Re: Crazy Custom Frame HobbitRe: Russell Huddy Russell Huddy 02/16/20 11:57AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/16/20 01:46PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/16/20 01:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/16/20 02:31PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/16/20 02:39PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/16/20 03:28PM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/20/20 04:30PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 02/20/20 04:56PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/20/20 11:48PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/20/20 11:57PM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/21/20 01:08AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/21/20 12:42PM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/21/20 03:38PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/21/20 01:43AM
  Re: Crazy Custom Frame HobbitRe: * * * * 02/21/20 03:08PM
  Re: Crazy Custom Frame HobbitRe: Born to be WillD Born to be WillD 02/24/20 01:06PM
  Re: Crazy Custom Frame HobbitRe: Dickie Thompson Dickie Thompson 02/16/20 08:57PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/16/20 10:47PM
  Re: Crazy Custom Frame HobbitRe: viv v viv v 02/16/20 11:09PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/17/20 11:03AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/17/20 11:49AM
  Re: Crazy Custom Frame HobbitRe: Jake P Jake P 02/17/20 03:28PM
  Re: Crazy Custom Frame HobbitRe: Duane Kahler Duane Kahler 11/21/20 06:56PM
  Re: Crazy Custom Frame HobbitRe: Alexis Wilber Alexis Wilber 02/20/20 04:17PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/24/20 01:21PM
  Re: Crazy Custom Frame HobbitRe: jumpsuit steve jumpsuit steve 02/26/20 10:35PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/26/20 10:45PM
  Re: Crazy Custom Frame HobbitRe: jumpsuit steve jumpsuit steve 02/27/20 09:46AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/27/20 11:14AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 02/27/20 11:44AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/27/20 01:00PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 02/27/20 01:34PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/27/20 02:03PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/29/20 12:31PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/21/20 02:15AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/25/20 02:19PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/25/20 10:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/25/20 02:22PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 04/20/20 11:57PM
  Re: Crazy Custom Frame HobbitRe: Emil Kniemel Emil Kniemel 08/04/20 02:21PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 05/10/20 07:55PM
  Re: Crazy Custom Frame HobbitRe: P D P D 05/11/20 09:41AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 05/11/20 11:45AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 05/11/20 12:15PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/20/20 01:36PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 07/20/20 01:57PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/20/20 02:27PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 07/20/20 02:53PM
  Re: Crazy Custom Frame HobbitRe: Emil Kniemel Emil Kniemel 07/20/20 03:51PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/20/20 04:10PM
  Re: Crazy Custom Frame HobbitRe: Emil Kniemel Emil Kniemel 07/21/20 01:16PM
  Re: Crazy Custom Frame HobbitRe: Born to be WillD Born to be WillD 07/21/20 05:02PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/21/20 05:48PM
  Re: Crazy Custom Frame HobbitRe: Emil Kniemel Emil Kniemel 07/21/20 05:53PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 07/20/20 07:26PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/20/20 09:19PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 07/20/20 11:52PM
  Re: Crazy Custom Frame HobbitRe: P D P D 07/21/20 10:13AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/21/20 03:31PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/21/20 03:34PM
  Re: Crazy Custom Frame HobbitRe: Satan 666 Satan 666 07/21/20 10:13PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/22/20 12:44PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/22/20 01:34PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/22/20 03:45PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/23/20 02:12AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 07/23/20 01:19PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/23/20 01:34PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 07/27/20 04:06PM
  Re: Crazy Custom Frame HobbitRe: Jesse Stephenson Jesse Stephenson 08/04/20 05:05AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 08/04/20 01:53PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 08/04/20 02:13PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 08/04/20 02:19PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 08/04/20 02:29PM
  Re: Crazy Custom Frame HobbitRe: P D P D 08/04/20 02:38PM
  Re: Crazy Custom Frame HobbitRe: Ryan Graeme Ryan Graeme 08/04/20 04:09PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 08/04/20 04:51PM
  Re: Crazy Custom Frame HobbitRe: Aaron Blair Aaron Blair 08/06/20 06:01AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 08/06/20 11:20AM
  Re: Crazy Custom Frame HobbitRe: alex . alex . 07/27/20 04:16PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 08/04/20 04:55PM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 08/05/20 11:32PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 08/06/20 12:34PM
  Re: Crazy Custom Frame HobbitRe: Aaron Blair Aaron Blair 08/06/20 06:19AM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 08/06/20 12:18PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 08/10/20 12:46PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/20/20 07:26PM
  Re: Crazy Custom Frame HobbitRe: Dickie Thompson Dickie Thompson 09/21/20 10:43AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/21/20 01:21PM
  Re: Crazy Custom Frame HobbitRe: Emil Kniemel Emil Kniemel 09/21/20 01:50PM
  Re: Crazy Custom Frame HobbitRe: Aaron Goldman Aaron Goldman 09/23/20 08:48AM
  Re: Crazy Custom Frame HobbitRe: TOP GUN™ ANDY ⚔ (LSLB) ⚔ TOP GUN™ ANDY ⚔ (LSLB) ⚔ 08/20/20 09:32AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/22/20 11:43PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 09/25/20 08:03AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/22/20 11:51PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/22/20 11:56PM
  Re: Crazy Custom Frame HobbitRe: Papa _ Papa _ 09/23/20 03:02AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/23/20 12:56PM
  Re: Crazy Custom Frame HobbitRe: Todd S Todd S 09/23/20 11:35PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/23/20 11:50PM
  Re: Crazy Custom Frame HobbitRe: Aaron Goldman Aaron Goldman 09/24/20 09:40AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 09/24/20 01:23AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/24/20 01:27AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 09/24/20 01:50AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 09/25/20 04:04AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/25/20 11:30AM
  Re: Crazy Custom Frame HobbitRe: Aaron Blair Aaron Blair 09/29/20 07:01AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 09/29/20 11:46AM
  Re: Crazy Custom Frame HobbitRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 09/25/20 09:50AM
  Re: Crazy Custom Frame HobbitRe: Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F Ľ̷̝̽͒i̶̛̼͑͠ȁ̸̧̛̽m̵̻̟̯̀̅ ̷͎̙̽̊F̶̲̺͑̓ F 09/25/20 09:53AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/25/20 11:28AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 09/25/20 12:20PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/25/20 01:18PM
  Re: Crazy Custom Frame HobbitRe: Aaron Goldman Aaron Goldman 09/25/20 01:59PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/25/20 02:05PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 09/25/20 02:13PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/25/20 03:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/30/20 02:09PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/30/20 02:11PM
  Re: Crazy Custom Frame HobbitRe: Aaron Blair Aaron Blair 09/30/20 10:21PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/28/20 10:31PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/28/20 10:34PM
  Re: Crazy Custom Frame HobbitRe: Graham Motzing Graham Motzing 09/29/20 08:40AM
  Re: Crazy Custom Frame HobbitRe: Graham Motzing Graham Motzing 09/29/20 08:41AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/30/20 02:31PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/30/20 03:07PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 09/30/20 03:10PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 09/30/20 03:16PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/01/20 02:52PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/01/20 03:15PM
  Re: Crazy Custom Frame HobbitRe: Dickie Thompson Dickie Thompson 10/01/20 09:23PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/01/20 11:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/25/20 03:39PM
  Re: Crazy Custom Frame HobbitRe: Ryan Graeme Ryan Graeme 10/25/20 04:42PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 10/25/20 07:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/28/20 12:06PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 10/28/20 01:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/26/20 01:41PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 10/26/20 03:49PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 10/27/20 02:44AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 10/27/20 09:11AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/26/20 01:54PM
  Re: Crazy Custom Frame HobbitRe: Dickie Thompson Dickie Thompson 10/26/20 01:55PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/26/20 02:10PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/26/20 04:07PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/26/20 05:20PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/27/20 03:39PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 10/27/20 03:58PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/27/20 04:02PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 10/27/20 04:52PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/27/20 04:05PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/27/20 05:39PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/28/20 12:55PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/28/20 01:25PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/28/20 01:27PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/28/20 01:41PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/28/20 01:49PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/28/20 01:54PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/28/20 03:31PM
  Re: Crazy Custom Frame HobbitRe: Bo Valencia Bo Valencia 02/17/21 12:51AM
  Re: Crazy Custom Frame HobbitRe: Bo Valencia Bo Valencia 02/17/21 12:54AM
  Re: Crazy Custom Frame HobbitRe: Wolf Wizard Wolf Wizard 10/28/20 06:32PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 10/29/20 10:00AM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 10/29/20 10:51PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 10/30/20 11:33AM
  Re: Crazy Custom Frame HobbitRe: * wormdirt * * wormdirt * 11/05/20 02:16PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 11/06/20 11:06PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 11/12/20 05:57AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 11/12/20 09:06AM
  Re: Crazy Custom Frame HobbitRe: Graham Motzing Graham Motzing 11/12/20 11:21AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/12/20 11:47AM
  Re: Crazy Custom Frame HobbitRe: Wolf Wizard Wolf Wizard 10/28/20 07:08PM
  Re: Crazy Custom Frame HobbitRe: Graham Motzing Graham Motzing 10/28/20 07:35PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/28/20 09:03PM
  Re: Crazy Custom Frame HobbitRe: P D P D 10/28/20 09:25PM
  Re: Crazy Custom Frame HobbitRe: Sander Mulder Sander Mulder 10/29/20 09:31AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/29/20 01:47PM
  Re: Crazy Custom Frame HobbitRe: Sander Mulder Sander Mulder 10/29/20 05:33PM
  Re: Crazy Custom Frame HobbitRe: Sander Mulder Sander Mulder 10/29/20 05:57PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/29/20 08:14PM
  Re: Crazy Custom Frame HobbitRe: L e e L e e 10/30/20 11:05AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 10/30/20 03:54PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/17/21 12:18AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/03/20 01:34AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/03/20 01:35AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/03/20 03:26AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/05/20 01:23PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 11/05/20 01:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/05/20 03:47PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/06/20 01:04PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 11/06/20 01:16PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/06/20 01:22PM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 11/06/20 02:17PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/06/20 02:29PM
  Re: Crazy Custom Frame HobbitRe: Ryan Graeme Ryan Graeme 11/13/20 10:41AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/13/20 11:41AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 11/13/20 02:11PM
  Re: Crazy Custom Frame HobbitRe: Graham Motzing Graham Motzing 11/13/20 02:14PM
  Re: Crazy Custom Frame HobbitRe: Satan 666 Satan 666 11/14/20 10:26AM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 11/14/20 11:03AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/16/20 04:08PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 11/16/20 05:54PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/16/20 04:09PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 11/17/20 12:12PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/17/20 01:17PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/21/20 01:08PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/21/20 08:53PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/22/20 01:39PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 11/24/20 10:13AM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 11/21/20 04:15PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 11/21/20 05:08PM
  Re: Crazy Custom Frame HobbitRe: Roger Suarez Roger Suarez 11/21/20 05:42PM
  Re: Crazy Custom Frame HobbitRe: Anthony Moody Anthony Moody 11/23/20 10:45PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 11/24/20 12:11AM
  Re: Crazy Custom Frame HobbitRe: P D P D 11/24/20 09:06AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 11/24/20 12:02PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/23/20 12:44PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/23/20 11:21PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/23/20 11:25PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 11/24/20 02:30PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 12/07/20 12:36PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 12/07/20 01:04PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 12/07/20 01:16PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 12/07/20 03:35PM
  Re: Crazy Custom Frame HobbitRe: P D P D 12/07/20 03:44PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 12/07/20 07:10PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 12/09/20 05:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 12/15/20 02:34PM
  Re: Crazy Custom Frame HobbitRe: Aaron Goldman Aaron Goldman 12/18/20 08:53PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 12/19/20 11:53AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 12/19/20 12:12PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 12/20/20 03:12PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 12/20/20 05:44PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 12/22/20 02:56PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 12/22/20 10:44PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 12/24/20 12:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/04/21 05:43PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/05/21 07:35PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/05/21 07:47PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/05/21 07:52PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/05/21 09:24PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/05/21 07:53PM
  Re: Crazy Custom Frame HobbitRe: Joe Schuitema Joe Schuitema 01/05/21 09:45PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/06/21 06:21PM
  Re: Crazy Custom Frame HobbitRe: Joe Schuitema Joe Schuitema 01/06/21 08:15PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/06/21 09:02PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/07/21 12:08AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/07/21 01:25AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/10/21 01:34PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 01/10/21 04:15PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/10/21 07:53PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/10/21 05:39PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/10/21 05:46PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/10/21 05:48PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/10/21 07:38PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/10/21 09:54PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/10/21 10:05PM
  Re: Crazy Custom Frame HobbitRe: Joe Schuitema Joe Schuitema 01/10/21 10:10PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/10/21 10:53PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/11/21 12:32AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/11/21 12:59AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/11/21 09:45AM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 01/13/21 07:50AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/13/21 12:20PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/11/21 06:02PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/12/21 12:52PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/12/21 01:20PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/12/21 02:54PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/12/21 02:56PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/13/21 03:10AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/13/21 12:10PM
  Re: Crazy Custom Frame HobbitRe: reynie domingo reynie domingo 01/13/21 02:55PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/14/21 12:40AM
  Re: Crazy Custom Frame HobbitRe: reynie domingo reynie domingo 01/14/21 07:13PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/14/21 07:56PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/14/21 10:33PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 01/15/21 10:02AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/15/21 12:24PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/15/21 12:21PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/15/21 12:43PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/15/21 12:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/15/21 12:31PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/15/21 12:46PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 01/15/21 01:06PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/15/21 01:30PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/16/21 06:43PM
  Re: Crazy Custom Frame HobbitRe: * wormdirt * * wormdirt * 01/16/21 09:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/17/21 12:52PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/17/21 12:23AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/18/21 10:49PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/20/21 03:33PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/22/21 12:01AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/20/21 08:39PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/20/21 09:11PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/20/21 10:43PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/21/21 12:47AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/21/21 12:48AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/21/21 01:09AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/21/21 11:59AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/21/21 07:43PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/21/21 08:09PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/22/21 12:07AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 11:46AM
  Re: Crazy Custom Frame HobbitRe: P D P D 01/22/21 12:01PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/22/21 12:35PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 01:37PM
  Re: Crazy Custom Frame HobbitRe: P D P D 01/22/21 02:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 04:47PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/22/21 05:21PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/22/21 05:32PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/22/21 09:39PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/22/21 10:02PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/23/21 12:59AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/23/21 12:36PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 01/23/21 05:04PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/23/21 05:10PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 01/22/21 05:02PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 05:45PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/22/21 05:52PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 06:28PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/22/21 07:13PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/22/21 07:51PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/23/21 11:23PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/24/21 01:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/24/21 12:00AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/24/21 12:48AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/24/21 11:40AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/24/21 01:23PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/24/21 04:53PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/24/21 05:30PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/24/21 03:03PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/24/21 03:48PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/24/21 07:47PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/25/21 02:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/25/21 03:16PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/26/21 01:34AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/25/21 03:32PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/25/21 03:36PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/26/21 11:07AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/29/21 08:48PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/29/21 10:20PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/29/21 08:52PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/29/21 09:08PM
  Re: Crazy Custom Frame HobbitRe: Joe Schuitema Joe Schuitema 01/29/21 09:14PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/29/21 11:16PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/29/21 11:55PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 10:21AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 11:18AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 11:56AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 12:00PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/30/21 12:38PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 01/30/21 01:34PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 02:07PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 05:38PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 05:49PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 05:57PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 01/30/21 07:06PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 12:41PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/30/21 12:50PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 02:07PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 05:54PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 06:51PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 06:53PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 08:16PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 08:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 07:01PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 07:16PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 07:23PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 01/30/21 08:32PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 09:51PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/30/21 11:16PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 11:32PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/30/21 11:32PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/31/21 02:44AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 03:54AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 01/31/21 12:11PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 02/01/21 11:30AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/31/21 12:48PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/30/21 11:36PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/31/21 12:17AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 12:26AM
  Re: Crazy Custom Frame HobbitRe: Joe Schuitema Joe Schuitema 01/30/21 11:39PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/31/21 02:06AM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 01/31/21 11:15AM
  Re: Crazy Custom Frame HobbitRe: Papa _ Papa _ 01/31/21 02:22PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 02:35PM
  Re: Crazy Custom Frame HobbitRe: P D P D 01/31/21 05:04PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 05:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/31/21 07:53PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 08:20PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 01/31/21 09:11PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 01/31/21 10:05PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 01/31/21 10:25PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 01:18AM
  Re: Crazy Custom Frame HobbitRe: * wormdirt * * wormdirt * 02/01/21 02:02AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 11:14AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/01/21 10:50AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:11AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:33AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/01/21 11:54AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 01:48PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 12:15PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 01:26PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 01:50PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 01:59PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:06PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:08PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 02:46PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 02:12PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:14PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:20PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:13PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 02/01/21 02:21PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 02:32PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 02:55PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 03:20PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/01/21 03:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 04:11PM
  Re: Crazy Custom Frame HobbitRe: P D P D 02/01/21 04:22PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 07:17PM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 02/01/21 09:40PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 08:09PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 09:24PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 09:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 08:12PM
  Re: Crazy Custom Frame HobbitRe: P D P D 02/01/21 08:42PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 10:56PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/01/21 11:04PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 11:16PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:11PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:37PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 11:42PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:38PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/01/21 11:50PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/02/21 12:03AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/01/21 11:57PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/02/21 12:15AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 12:01AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 12:06AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/02/21 12:11AM
  Re: Crazy Custom Frame HobbitRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 02/02/21 10:31AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/02/21 12:42PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 11:36AM
  Re: Crazy Custom Frame HobbitRe: baird co baird co 02/02/21 11:49AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 11:57AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 12:08PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/02/21 03:55PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/02/21 09:28PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/02/21 10:48PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/02/21 11:49PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 02/03/21 11:14AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/03/21 12:21PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/03/21 12:33PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/03/21 02:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/05/21 05:24PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/05/21 05:28PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/05/21 05:50PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/15/21 09:57PM
  Re: Crazy Custom Frame HobbitRe: Rubble Raiser Rubble Raiser 02/17/21 02:05AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/20/21 07:37PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/20/21 09:43PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/20/21 11:32PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/22/21 11:56AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/22/21 12:07PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/22/21 03:58PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/22/21 10:15PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/22/21 11:47PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/23/21 01:12AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/23/21 10:24PM
  Re: Crazy Custom Frame HobbitRe: Jeremy Freeze Jeremy Freeze 02/24/21 12:01AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/24/21 11:18AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/24/21 11:20AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/24/21 01:16PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/24/21 01:17PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/24/21 03:50PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 02/24/21 04:04PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/24/21 05:03PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 02/24/21 07:30PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 02/24/21 07:58PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/24/21 01:31PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/24/21 10:01PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 02/25/21 07:33AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 02/25/21 10:56AM
  Re: Crazy Custom Frame HobbitRe: Jeremy Freeze Jeremy Freeze 02/25/21 11:56AM
  Re: Crazy Custom Frame HobbitRe: Papa _ Papa _ 02/25/21 01:07PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 02/26/21 07:33AM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 02/26/21 07:42AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 02/26/21 02:51PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/01/21 11:18PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/01/21 11:27PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/02/21 01:04AM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 03/02/21 10:44AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 03/02/21 11:15AM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/02/21 11:32AM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 03/02/21 09:38AM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/02/21 11:56AM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/02/21 12:07PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/02/21 12:17PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/02/21 12:30PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/02/21 12:40PM
  Re: Crazy Custom Frame HobbitRe: Dirty30 Dillon Dirty30 Dillon 03/02/21 12:55PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/02/21 01:10PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/02/21 01:22PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 03/02/21 01:50PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/02/21 01:02PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/01/21 11:34PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/02/21 11:09AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/02/21 12:58PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/02/21 05:06PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/02/21 05:43PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/02/21 07:26PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/02/21 10:17PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 12:17PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:30PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/03/21 12:31PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:36PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/03/21 12:37PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/03/21 12:40PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:39PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 12:37PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:41PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 12:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:45PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 12:49PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 12:56PM
  Re: Crazy Custom Frame HobbitRe: Tweaker trash Tweaker trash 03/03/21 01:14PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 01:36PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 01:37PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/03/21 03:59PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/03/21 05:26PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 06:23PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/03/21 07:30PM
  Re: Crazy Custom Frame HobbitRe: Joel P Joel P 03/03/21 07:42PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/03/21 08:24PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/04/21 11:02AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 03/04/21 11:05AM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 03/04/21 11:51AM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 03/04/21 02:29PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/04/21 11:07AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 03/04/21 11:18AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/04/21 11:33AM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 03/04/21 11:50AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/04/21 04:19PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 03/04/21 05:09PM
  Re: Crazy Custom Frame HobbitRe: Mike Boyd Mike Boyd 03/09/21 02:36PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/04/21 05:37PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 03/04/21 10:54PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/09/21 11:36AM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/10/21 04:40PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 03/22/21 07:06PM
  Re: Crazy Custom Frame HobbitRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 03/23/21 02:18PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 04/01/21 01:37PM
  Re: Crazy Custom Frame HobbitRe: Jay Rivett Jay Rivett 04/01/21 06:04PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 04/02/21 02:08PM
  Re: Crazy Custom Frame HobbitRe: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 04/12/21 01:43PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 04/09/21 06:13PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 04/09/21 06:18PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 04/09/21 06:20PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 04/12/21 01:27PM
  Re: Crazy Custom Frame HobbitRe: JBOT Admin JBOT Admin 04/12/21 01:36PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 04/12/21 01:41PM
  Re: Crazy Custom Frame HobbitRe: Daniel '' Daniel '' 04/12/21 01:52PM
  Re: Crazy Custom Frame HobbitRe: Colin Ratcliff Colin Ratcliff 04/12/21 04:47PM
