Re: Pug/Moby Le Partie Timing
Daniel '' /
1.1 is a good place to start for kitted bikes, with static timing you won’t be able to run much more advance without overheating. On a polini w port engine I had for a bit, it timed suuuuper conservative and one time i pulled up to a stop light and everything is fine, then when I went to take off it had started running backwards and I rear ended myself on the car behind me. Shut it off and restarted and it was totally good again. Spooky!!
