Re: Pug/Moby Le Partie Timing
Toledo Riot /
> Daniel '' Wrote:
> 1.1 is a good place to start for kitted bikes, with static timing you
> won’t be able to run much more advance without overheating. On a polini
> w port engine I had for a bit, it timed suuuuper conservative and one
> time i pulled up to a stop light and everything is fine, then when I
> went to take off it had started running backwards and I rear ended
> myself on the car behind me. Shut it off and restarted and it was
> totally good again. Spooky!!
That is amazing, I’ve only seen one bike run backwards, someone installed a Pietcard backwards on an e50, he racked himself on the forks/bars
Anyhow to your point of static timing, as the stock Le Partie boxes are. All my 103’s besides my “stock-ish” bike are liquid cooled, I’m changing it to a Doppler thanks to the treats sale. I also picked up one of the replacement Le Partie boxes that has a curve, I’m gonna give it a try on this motor
