Re: Pug/Moby Le Partie Timing
Daniel '' /
I would still time it for 1mm at max rpm, I’m not sure what the curve of the box you got is. I actually prefer static timing on hot single variated bikes as you don’t need the advance with a clutch pulley and variator doing all the work to keep you at xxxx rpm.
