Re: Pug/Moby Le Partie Timing
Toledo Riot /
> Daniel '' Wrote:
> I would still time it for 1mm at max rpm, I’m not sure what the curve of
> the box you got is. I actually prefer static timing on hot single
> variated bikes as you don’t need the advance with a clutch pulley and
> variator doing all the work to keep you at xxxx rpm.
On a v1 the curve on the 2041 boxes is a life saver, so I figured why not? Guess we’ll find out!
