Re: Pug/Moby Le Partie Timing
JBOT Admin /
Yes and that's what I do too.
but fuck using mm.
Degrees btdc ftw.
Haven't found a bike yet that doesn't like at least 23deg initial then retarding down to 18deg at wot. As long as you have enough cooling you're golden. Wc heads or good wicking standard AC heads with a good combustion chamber and squish.
BUT...,if you're a member of the 12k or higher rpm all the time club you might wanna drop that down a bit, to your taste
