Who says you can't mod a Solo? 14.12 Dellorto clone with intake bored out to 14mm and matched to the reed block, Treats Minarelli mini shitter circuit pipe bolted right up. A little less off the line, nice gains up top.
Solo Columbia
Re: Solo Columbia
Seems like it would be more quiet with the stinger pointing against the ground but How loud is that pipe with no silencer,
Re: Solo Columbia
Those pipes are not as loud as you would think. Almost don’t need a baffle, but of course you should have one. I modded my solo to get into the mid forties. I better pipe would net you more substantial gains. I was running a Peugeot ninja pipe and a puch wheel so I could re gear it to 11x45. Was actually really fun. Make sure you keep the clutch idler bearing greased.
Re: Solo Columbia
Not too loud at all without a baffle.
Re: Solo Columbia
Pics of your setup?
Re: Solo Columbia
Re: Solo Columbia
that faco circuit pipe is a baffle, its just made to look like a circuit pipe.
i cut one all apart years ago, its full of stupid tubes and plates fulla holes.
just make sure you keep it fulla antifreeze! haha.
Re: Solo Columbia
Wonder how similar it is to a Cobra sito
Re: Solo Columbia
Interesting about the pipe, who would know without cutting it up? Not many bolt right on options here.
Re: Solo Columbia
I've always liked those solo bikes, good job
