NU50 Express Exhaust options
KEITH MARSHALL /
not much around for exhaust for this NU50 Express, seen expansion flat set up
for hobbit but you loose kickstand. how about the longer pipes that run up the side
made for a hobbit? performance loss? expansion chamber not as drastic.
Thoughts? thanks for your time. old muffler carboned up and plugged.
Re: NU50 Express Exhaust options
Clean it out . Oven or drain cleaner . Fill , let work , drain , rinse , repeat .
Only cost you a buck at the dollar store .
KEITH MARSHALL /
Thanks for the advise, will probably do that. im at 4500 feet above sea level and was hoping for a little performance increase as well. as in the pipe options.
> the pipe options.
You might try raising the carb jet needle clip a position or two .
After you clean the pipe , of course .
There are literally more NU50 exhaust options now than there ever has been before...
KEITH MARSHALL /
Examples please, that’s why I’m asking for help. Your input would be great.
Thank you
Did you not see the hyperlink in my last post?
Here: https://www.treatland.tv/SearchResults.asp?Search=nu50+exhaust
Jack Rutherford /
Yea there’s 4 on that page if you click the link - more if you buy the mlm header and couple it with whatever else your little heart desires. (edited)
Get your bike running as good as possible in stock configuration before you start adding other variables or you may end up with a can of worms that not even the hungriest fish would want ..
KEITH MARSHALL /
Thank you. Good start.
Captain Janeway /
If you don't feel like buying a new pipe or burning out your old one (throw it in a bonfire to burn out the carbon), there's always this:
Have fun.
