Re: modifying stock cylinders and pistins
Dirty30 Dillon /
There are a bunch of threads regarding adding aux exh ports to stock-ish cylinders, as well as chamfering the piston crown into the ports to clear at BDC, cutting windows/ pistons, as well as ringland porting, etc.
A little bit of research will give you a better idea.
