Starflight VA 2
Hey new to moped life and been the owner of a 79 Bat with a M48 things pretty mint and has really rode well. Waiting on a new clutch pad becuase mines worn to shit. Looking for ideas on boosting up my speed. Not looking for top end project. Just wanted advise on a carb recommendations? Is an aftermarket exshaust worth losing the clean original look of the stock chrome one? Has 50th rear sprocket front one is 12tooth i believe. Just trying to squeeze some speed out this old bat. Thanks in advance
Re: Starflight VA 2
Not really much for bats. But a dellorto 15/15, intake and a slip on chamber will get you some more pep...I believe the cylinders have alot of room for improvement porting wise too.
Re: Starflight VA 2
Re: Starflight VA 2
Thanks man
Re: Starflight VA 2
My Batavus city does 43. Pipe/kit/Mikuni/remove balls in clutch spring
Kits are hard to come by now though (edited)
Re: Starflight VA 2
Sweet Bat! Won't taking the balls out toast my clutch. Ill have the new pad in today so since im already in there I'm thinking of giving it a try.
Re: Starflight VA 2
No it'll just delay engagement until higher rpms. Which is what you want, more power up there.
Re: Starflight VA 2
Good stuff I'm gonna give it a try when i replace the clutch pad. Thanks
Re: Starflight VA 2
> try.
When I bought this bike it had no balls in this clutch. The clutch plates are grooved to the point that no new pad will fix it, so the clutch always stayed engaged. I would replace the balls with lighter ones, I think removing the balls will shred your clutch with a lot of riding
