Re: Sachs, carb restriction, and skavenging.
Graham Motzing /
yeah i'm pretty sure if anyone is saying that its because the midrange is hard to tune on the square bing- there is no needle so without an airbox it runs lean and you get a midrage boggy doggy.
i have never noticed a difference sweating +/- 2 mm or so on the intake. i've built intakes where i really sweat the diameter and they usually don't run any better or worse than ones that i just slap together out of whatever. you'll probably want to do a couple plug chops anyhow once you get your whole setup dialed in, everything from air in your tires to fancy neon grips on the handlebars.
