Re: Sachs, carb restriction, and skavenging.
. Chudas. /
> Graham Motzing Wrote:
> yeah i'm pretty sure if anyone is saying that its because the midrange
> is hard to tune on the square bing- there is no needle so without an
> airbox it runs lean and you get a midrage boggy doggy.
> i have never noticed a difference sweating +/- 2 mm or so on the intake.
> i've built intakes where i really sweat the diameter and they usually
> don't run any better or worse than ones that i just slap together out of
> whatever. you'll probably want to do a couple plug chops anyhow once
> you get your whole setup dialed in, everything from air in your tires to
> fancy neon grips on the handlebars.
lol dont forget my clip in pedals
