Does anybody know anything about jetting sizes for an 80cc Athena?
Running a 15mm Bing 2.17 atomizer 78 jet 2nd ring from top
If sach Reed kit should be higher jet but it depends what filter you use and if you’re using metal reeds I suggest you change them to fiber ones
80cc non reed Athena. Jet size
Pipe? Elevation? Filter?
The question needs more information to give a better answer.
Following for info.
I'd start mid 90s. I dunno anyone running such a small carb on such a big kit, it's pretty comparable to like the 74cc airsal or metrakit - puch's big "80cc" piston ports; and those everybody runs at least a VM18 if not PHBG21 or TM24.
But folks use 15bings on polinis all the time, high 80s jetting
I'm at 0ft elevation. My pipe is a tomos estoril custom sidebleed and shorter header. 15mm Bing. 78 jet currently.
No filter as of yet.....thinking inline check valve.
