Re: 1977 A3 Tomos stator replacement/ upgrade
Graham Motzing /
I mean I'll send you an a3 stator if you want one but usually they are easy to fix. All tomos use the same ignition if you replace flywheel and stator together, also any Puch za-50 will fit along with about half of all mopeds
You can do the cheap replacement internal coil one from treats but you still want to put good points in there
