Re: What can you tell from these pics?
Overpriced Parts /
Probably just a bad head gasket or not torqued correctly in sequence But it could be that the head has the wrong chamber/it’s made for 46mm instead of 45mm as well as I bet you didn’t base space, set squish or nothing,
Your set up should be blasting at 55+ mph if setup and timed/tuned correctly so you’re not making much that much more power than you can get out of a stock ported cylinder and a 14mm carb
