Kitted ZA50 Shifting
This is my second ZA50
The first one (treats 50cc Kit) with a flipped 2nd had a very controllable shift point, little blip and release and it shifted.
This newer one (tccd 70cc kit) the shifting is way less controllable. I can rev 1st to the Moon and it doesn't drop into gear. I have to keep the revs kinda low and kinda roll off and usually it shifts. The point is I can't control it that well.
New pucks and flipped second, I plastigauged the end float when I put the pucks in and it was cool
Is this a high power kit thing or do I need to strip the trans and go poking around
Re: Kitted ZA50 Shifting
Probably Fred /
You may have to look inside a few Rollers could be in wrong or something could be broke in there
* wormdirt * /
Poked around this morning. Everything is kosher.
Put 0w-20 oil in it and it help a little but shifting still doesn't feel very controllable
> very controllable
Yeah, but is it GLATT kosher??
* wormdirt * /
> feel
> > very controllable
Maybe not roff kosher but close enough
You might just not be used to the revs you get in first with a larger kit. Wring it out a little!
* wormdirt * /
That was my first thought, but 1st just revs and doesn't go any faster
What's your gearing?
* wormdirt * /
20 x 37 (smallest rear for a snowflake)
I had a 21 on the front but I couldn't really pull when 2nd dropped
Kinda agree with Ken then... post pics of the rollers in the first speed gear?
* wormdirt * /
* wormdirt * /
you know what i just realized, the first and second gear shaft has some play in it. I can pull it away from the clutches some. I'm pretty sure that is normal but I don't know
And It does "go somewhere" in first, it just tops out very quickly (edited)
somethins wrong.
* wormdirt * /
That's what I'm starting to gather
* wormdirt * /
Crisis averted, the techno circuit I had on there wasn't pulling into gear very well.
For shits and giggles I put a biturbo I had laying around night and day difference. I feel comfy putting a 21 on the front now for sure.
Time to buy a crank pipe?
