Airsal a35 query.
Noticed that at tdc, the transfer ports inside the cylinder are covered slightly (aprrox. 3mm)by the piston. Is this normal? Should I shave the piston so that they are fully open?
the black mark is where the cut off point is.
Cylinder and piston are airsal 44mm a35.
Cheers all. (edited)
Re: Airsal a35 query.
Dirty30 Dillon /
You could match them, or not.
But I would be worried about the scorching on the back side of the piston crown, indicating that your temps are fairly hot
gas and oil are going to flow in through those transfer ports regardless if u want to put the extra work to open it 3mm then do it. I leave it as is to keep the integrity and strength of the piston/ kit. I would look at the exhaust port that's where power can be gained easily.
Cool. I'll leave the piston alone then. I'm a bit scared about raising / lowering any thing intake or exhaust wise at the moment but I'm getting a dremel delivered tomorrow so I'm going to widen everything by just a couple of mm and see what happens. Very excited though :)
> Saabsonettguy . Wrote:
This
Wow! That is one hot Piston pin. What carb are you running? Jet?
I'm surprised that isn't seized, you mighta cought it just in time.
♣Slew Foot♣ /
Seal leak statorside?
Oh yeah that was an old piston from and older incarnation of the bike that was was horrid (me not having a clue what I was doing) that i had knocking around.
Got it all together yesterday.
Left the piston alone..
Widened intake ports by about 2mm either side
Widened exhaust by about 3mm either side then raised by about 1mm
Chamfered everything
Case matched
Polished the exhaust pot the best I could
Fuck me... it's so much better than before.
Loads more torque / general power throughout.
Bike is tomos a35
Airsal 44mm
mlm 15 intake
Sha 15 clone
68 jet
1st Gear Jammer clutch with light springs
Estoril pipe
Wish I'd done this ages ago now.
Get a bigger carb intake a reeds now! Another good jump in performance
