Re: Hacking an Estoril for higher rpms
> JBOT Admin Wrote:
> I have become more stupid reading this thread
You and me both!
The cone in an Estoril IS NOT A RESTRICTION
For fucks sake people this is not a French pipe with a washer spot welded in the header! The cone is designed to make the Estoril perform like a circuit pipe with out all the noise, while simultaneously giving you more mid range the. A circuit could create!
ITS NOT SOLD AS A HIGH RPM PIPE! If you want a high rpm pipe, BUY ONE. Taking the cone out back in the day (read 8+ years ago) was a trick we used to turn them into a high rpm pipe, because back in the dark ages we didn’t have access to all the sweet pipes we have today! It was an act of desperation.
Ghhhhhaaaaaa go read old posts before you post the same re-tread subjects! When you click on the performance tab, the first post is a sticky from Simon encouraging your to read and learn from the past before you post shit information that has been gone over 100 times
“HaS AnYOnE UsEd a kStAr On A pOOk MaXi!?!???”
I've removed said cones inside a leo Vince ZX and it narrowed the band for sure, but I needed it as a high rpm pipe so the lows I lost I made up for on top.
Tweaker trash /
> Toledo Riot Wrote:
> You and me both!
> of desperation.
Thank you
Overpriced Parts /
> Toledo Riot Wrote:
> You and me both!
> of desperation.
Not a restrictor but a rpm restrictor/limiter
After removing funnel in about 10 of them, 3 of them found blob of weld blocking stinger pipe about 10-20% of diameter in some cases so you can find a restriction in a sense
♣Slew Foot♣ /
Bends. If it's restricted at the throat it increases the velocity of the hot gases causing it to expand in the chamber faster and cooler in the chamber but the throat heats considerably mine is mostly brazen. And it spigot mounts. But yeah mine had a seam inside the stinger as well as a bead. The baffle kinda extends the length so if you hack it higher rpms. The stack needs to be covered in the rain or its like a steam blast when the pipe gets hot enough.
